Author Topic: front brakes keeping locking up  (Read 2174 times)
4wheelworks
  • Member since Jan '10
« on: Aug 23, 2010, 01:03:54 PM »
my 1994 4runner, the front brakes will lock up and not release pressure until you take the cap off the master cylinder,   it has new calipers, master cyl, front brake lines, a good used booster, back brakes are working fine,  pedal will get rock hard,  any ideas will help,
zippo
  • Turtle Points: 550
  • Male Posts: 1,556
  • Member since Nov '08
    • oppiz.net
Re: front brakes keeping locking up
« Reply #1 on: Aug 23, 2010, 01:06:52 PM »
Could be a DOA master cylinder?
If you see it, its for sale.
crazykooter
  • Turtle Points: -369
  • Male Posts: 1,418
  • Member since Apr '09
  • Located in Byron, CA
« Reply #2 on: Aug 23, 2010, 06:21:03 PM »
Both front tires lock up ?   Tho normally master cylinders dont cause locking like this unless the plunger inside is sticking or air in the lines.  If it was sticking then the brake peddle would have a lot of play in it when the brakes lock up.   Poss that your getting sort of a vapor lock on the brakes.   Does it do it under light braking or just harder braking ?   Take a few mins and a quart of brake fluid and flush the whole brake system.   There is a bleeder on the bottom of the master as well.
  • Momentum Man
  • Turtle Points: 730
  • Male Posts: 13,860
  • Lego Enforcement
    • Spinnin4s 4x4 Club
« Reply #3 on: Aug 24, 2010, 03:20:13 AM »
Had this happen on my 86 turbo, it was the plunger as stated. It would get stuck and not release for around 5 min. I took the MS back and got another one and everything was fine, on a side note they did give me the wrong MS for a 22re instead of a 22ret they are different.
4wheelworks [OP]
« Reply #4 on: Aug 25, 2010, 08:06:05 PM »
on thew search for a good used brake booster/ master cylinder combo  who has one, how much and thanks for the help!
Burl
  • Turtle Points: 271
  • Male Posts: 389
  • Member since Jan '07
  • Wannabe Smokejumper
« Reply #5 on: Aug 27, 2010, 08:20:01 PM »
I was having a similar issue with mine, apparently a 1 inch bore ms is not compatible with 4cyl calipers.
« Reply #6 on: Aug 28, 2010, 05:34:15 PM »
yes they are, ive been running the one inch bore sold by Marlin for about 2 1/2 years.  unless the master you have is one equipped with ABS.
Burl
  • Male Posts: 389
« Reply #7 on: Aug 28, 2010, 09:24:55 PM »
That's weird because when I brought my rig into your guys store I was told to upgrade to the v6 calipers and vented and slotted rotors.  That seemed to fix the front brakes locking up.  Idk maybe was justa fluke but the 4 cyl calipers with the ms I purchased from marlin was a bad combo but what i've got now works great.
crazykooter
  • Male Posts: 1,418
« Reply #8 on: Aug 29, 2010, 12:54:40 AM »
I ran V6 master and a dual booster with stock 1st gen truck calipers for a while and never had an issue.  Only reason I upgraded to v6 calipers was due to the ifs hub swap with fj80 rotors.  Only did that to make the front end wider without spacers.
  • Turtle Points: 1128
  • Male Posts: 9,757
« Reply #9 on: Aug 29, 2010, 01:15:02 PM »
I put a 1" mc on my first gen with no other mods and I have absolutely no feedback, just a very hard pedal that barely moves.  I could lock up the brakes if I didn't get used to it, so maybe that's why yours were locking up  :dunno:
Last post Sep 29, 2005, 05:15:45 AM
by 1kz
Last post Aug 29, 2006, 10:42:23 AM
by 79coyotefrg
Last post Apr 07, 2010, 05:43:56 AM
by birfection
Last post Jan 17, 2012, 11:14:47 PM
by yotajohn
Last post Mar 09, 2014, 10:00:13 PM
by Rocksurfer
