axle length for ford 9 inch in 94 ext cab
Started by 4rox, December 23, 2004, 08:48:50 PM
4rox
I have a 94 ext cab with a 5.7 vette engine/narrowed 9 inch.I snapped the drivers' side axle at the splines.i'm trying to figure out if both axles are of equal length so i can find a replacement.Each axle has been set up for 6 lug wheels.Where do I start? The axles /housing were from the doner (rolled 85 toy) whos origin is unknown.The studs are screw in and long like on drag cars.Any info would be highly appreciated.
I'd rather push a Toyota than drive a Jeep!!!
Bitchin......I'm no help on this one, but,  bitchin ride.........Nate
kyle_22r
i'm confused...you say you have a 9" but the axles are from an '85 toyota?  so you're saying the ford 9" was originally in the old truck?
have you taken both axle shafts out and compared their length?
FATB0Y
4rox
The ford 9 inch was on the 85 which had been rolled.The last time I had the axles out,I think that the drivers' side is shorter.There are 28 splines on the axles.
FATB0Y
4Rox I'll say it again that is a bad azz rig :thumbsup:
Pregnant dogin???  So it won't even let me say the word "bi-tch-in"?  Ok,  guess I just hafta say your truck is pregnant dogin then, pregnant dogin indeed,   Nate
reklund5
turn of the censor stuff in your preferences, then you can type whatever you like.
Pull the other shaft and call up Mark williams axles.  They are about $200 for a new set of shafts.
kyle_22r
with a big motor you might want to consider upgrading to at least 31 spline shafts
