chopping an antenna
Started by 87hillbillyoter, July 31, 2010, 07:07:49 PM
87hillbillyoter
hey guys i know nothing about antennas or whatever so if this is a stupid question tell me. i bought a 5 n a half foot antenna not thinking that it would hit everything above me on the trail until i wheeled with it. well im gettin sick of that clanging noise and i wanted to know if i could just cut it down a little bit. ive heard you cant, and ive also heard you can. thanks yall
1987 SAS'ed toyota 4x4 pickup 22re swap
build up- http://board.marlincrawler.com/index.php?topic=75111.0
crazykooter
If your just going to talk to people close by then your fine.  The length of the antenna is more about distance.  Example is when your adjusting your CBs SWR which is how you tune your CB to get maximum distance.  When adjusting this you simply raise and lower the antenna till it matches.  So cut it but dont expect it to get out that far.  Also where you mount it has to do with the distance as well.  If its a fiberglass whip then remove the rubber cap on the end then cut and put the cap back on.
87hillbillyoter
thanks man. yea thats the one thing keeping me from cutting it. i dont know if you can see it in this pic but this is where its mounted
crazykooter
I wouldnt bother cutting that.  Its a steal whip and looks to be a wilson 3000 or 5000.  Just move it down to the bed rail if you can.  If you must cut it then cut it so the top of the antenna is what you plan to keep.  You want to keep the tip as high as you for the best range.
86rustbucket
dont cut it,   it wont work for :pokinit: if you do, you might as well give it away
just sell it and buy a magnetic mounts with a short rubber whip
TURBO
MY BUILDS: http://board.marlincrawler.com/index.php?topic=76463.0 :woohoo:
More than tread lightly, leave it like you were never there, nor anyone else.
I AM :screwy:!!!
Quote from: Hank Williams Jr. on September 19, 2008, 09:55:09 AM
"These dusty roads ain't streets of gold
But I'm a happy right where I'm at"
Quote from: Wermz84 on September 19, 2008, 09:55:09 AM
Marlin is like the Chuck Norris of the rock crawling world.
