Hello everyone from NE TN
Started by weasel159, July 31, 2010, 08:05:16 AM
weasel159
I'm a noob here and I've finally decided after three years it was time to start building my 87 yota up. I am starting with an SAS. I am new at all this so I will be asking lots of stupid noob questions as I build the truck. The first being I have found someone with front and rear straight axles gear matched 4.10s and wants $250 for both. Being new I dont know if its a good deal or not. Anyone have any input TIA...
4.10 is the base aka stock gearing for almost all yota trucks
what year is this truck and is it a 5spd or auto, 4 or 6 cyl,  and what do you plan on doing with it??
weasel159
That would probably be helpful. 87 4cyl 5spd man ifs 4.10. Its a learning project so it will probably go through many stages. For now I want something all around capable and be able to do some mild crawling.
dont worry about doing a SAS right away, i would look into a mild lift, maybe a 2 inch body lift and get some 33's and some differential gearing./  4.88 gears are good for a 33 inch tire.
a rear locker and some body armor would make it a capable rig for sure.
run that IFS till it falls off (the ifs will take a lot of abuse)
weasel159
Yea I figured I would run the IFS for a little while... I thought if that was a good price on some axles I could get them and put different gears in them while I am getting everything in line for the swap get some other stuff done to the truck.
gtoyonrocks
Dude, that's a smoking deal. I would jump on that.....
that was for the entire axles??   :doh:
possume22
toe
Me
weasel159
Quote from: 79coyotefrg on July 31, 2010, 07:06:38 PM
Yes for the entire axles and possible springs...
weasel159
Quote from: possume22 on July 31, 2010, 07:56:55 PM
where are you in east tn
Way to the Northeast almost in VA and NC... Johnson City, Bristol, Kingsport area.
weasel159
Well my "smoking deal" might have to wait. I was taking off the tranny to do the clutch and when I pulled the sticks for the tranny and transfer case realized the rubber seats for them had disintegrated... Can I just flush that crap out of the t case???
Quote from: weasel159 on July 31, 2010, 09:14:35 PM
i wouldnt worry about those they disintegrate pretty quickly
http://www.marlincrawler.com/transmission/parts-upgrade/heavy-duty-shift-lever-ball-seats
axled89
i love oregon wheelin.
