Author Topic: fuel injection  (Read 1451 times)
motoracer
  • Turtle Points: 12
  • Male Posts: 319
  • Member since Sep '07
  • my geen bean
fuel injection
« on: Jul 16, 2010, 05:49:18 PM »
« Last Edit: Jul 16, 2010, 06:43:35 PM by 79coyotefrg »
pie
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
Re: fuel injection
« Reply #1 on: Jul 16, 2010, 06:47:41 PM »
i think ive seen somebody that had that but i cant remember for sure.
crazykooter
  • Turtle Points: -369
  • Male Posts: 1,418
  • Member since Apr '09
  • Located in Byron, CA
Re: fuel injection
« Reply #2 on: Jul 16, 2010, 07:07:35 PM »
Its a early Volkswagen efi setup and are very reliable but for a gas engine I wouldn't bother.  They are ideal for diesels tho.   The main reason I wouldn't put one on a gas engine is due to the primitive fuel monitoring. They tend to run very rich.  If your truck is a trail rig only then I would say go for it.  If your seriously thinking bout that setup then make one yourself.  There is no computer.  As long as you have a electric full pump and good vacuum then you just need to go to picknpull and look for a I think its 81-85 Volkswagen gti or jetta with the 1.8L engine.  If you want to see how simple that system is google CIS injection. Basically there is a diaphragm on the bottom of the unit which pushes fuel thru the injection lines which is the main reason why they tend to run rich.
motoracer [OP]
  • Turtle Points: 12
  • Male Posts: 319
  • my geen bean
Re: fuel injection
« Reply #3 on: Jul 16, 2010, 07:33:11 PM »
thanks my weber sucks. thinking going  somekind of fuel injection with out changing to much on my truck.
pie
Tyler82toy
  • Male Posts: 81
  • Member since Jun '09
Re: fuel injection
« Reply #4 on: Jul 16, 2010, 09:28:12 PM »
when i was looking into fuel injection for my truck i came across this kit that uses gm throttle body and sensors. the listing says straight six but if you look to the right the have a option for the 2.4 http://www.affordable-fuel-injection.com/ixxocart/products/Toyota_Complete_TBI_System_w_Distributor-17-16.html
motoracer [OP]
  • Turtle Points: 12
  • Male Posts: 319
  • my geen bean
Re: fuel injection
« Reply #5 on: Jul 17, 2010, 04:19:00 AM »
yes i looked at that . anything i go to do is going to cost about $1000.  i want to keep it cheap, because im going to do a vw 1.9 swap . it well take a while to find a engine and all my stuff to do the swap. little at a time.  but i need to get my truck running good until then. and my weber ant cutting it. dont idle right ,stals,floods ,hard to start , just tired of dealing with it. might put stock carb back on but it need to be rebuilt.
pie
Last post Aug 22, 2003, 09:30:14 AM
by mhemingw7
Last post Sep 23, 2004, 11:40:06 AM
by BigMike
Last post May 05, 2009, 06:18:22 PM
by Tallchevy
Last post Jun 28, 2009, 11:56:33 AM
by crawlerdad
Last post Aug 29, 2013, 09:17:14 PM
by steveco.
