Author Topic: different gen clutch master and slave work together?  (Read 1479 times)
dntsdad
  • Turtle Points: 8
  • Member since Jan '09
    • My 3.4 swap into a 92 pickup
« on: Jul 11, 2010, 08:50:40 AM »
I am getting ready to swap a 3.4 r150(Tacoma) into my 92 pickup and had a r150 originally.
I want to use my existing clutch master since it obviously bolts up (not even sure....maybe the Taco one does as well) but I have to of course use the Tacoma slave on the tranny.
Anyone think there will be any issues on mixing these two together? Just trying to avoid surprises later.
thanks
92 Toyota x-cab, 3.4 swapped, R150 5 speed, 2.8/4.7 SAS
My 3.4 swap http://www.yotatech.com/f160/had-officially-began-3-0-auto-3-4-manual-92-ex-cab-196823/
90 Runner
  • Male Posts: 13
  • Member since Jul '10
    • CT4WD
they would need to have the same diameter and piston length for it to work. The master needs to be able to move the amount of fluid that the slave needs. Check the size of the two masters if they match then you shouldn't have any problems
dntsdad [OP]
  • Turtle Points: 8
without having a Taco master here, how can i find that out? Does anyone know of any resources available with that kind of information?
THANKS!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
« Last Edit: Jul 11, 2010, 09:45:40 AM by dntsdad »
90 Runner
  • Male Posts: 13
    • CT4WD
give your local dealer a call they should be able to pull that up easy
Last post Dec 01, 2007, 06:05:28 PM
by DTB
Last post Jun 28, 2008, 01:41:44 PM
by mybluetoy
Last post Jun 28, 2009, 01:04:02 AM
by jimbo74
Last post Dec 28, 2009, 11:55:29 AM
by junya92toy
Last post Jan 23, 2019, 06:41:34 PM
by 4Reak Show
