Getting my gas gague to work
Started by GRM, December 16, 2004, 12:43:10 PM
GRM
I swaped a SR5 cluster out fo an 84 pickup (carbed) into my 85 4runner (EFI). Ever since then, my gas gague is pegged. I assume the ohms or whatever it is is different, so thats why it wont work. Is there a way to get it working, or am I better off sellling it and getting a EFI one?
Marlin
This has nothing to do with the fuel sender.
Both carbed and efi trucks use the same ohm gas tank sender units.
The problem is that the gas tank wire is going to a ground and has a result, the fuel guage is showing a full tank.
You need to trace the cluster gas tank wiring.
I would compare both clusters, and move the wires to the proper position in the wiring plug as required.
Marlin
