93 Toyota 4Runner
Started by Lizard_lips, June 13, 2010, 02:54:41 PM
Lizard_lips
93 Toyota 4runner 3.0 184xxx on the clock, stock 5 speed, trail gear v6 to 4cyl adapter plate. Toy crawl box with total spline marlin crawler 23 spline stock gears upgraded ball and spring in toy box. OTT Dana 300 adapter. Dana 300 stock gears, fully rebuilt. Advance adapters front 32 spilne output and JB conversions 32 spline rear output/housing, high angle drive line toy tripple drilled flanges. 4x innovations toy crawl box mount, Atlas support ring mount. Cross member made from 1.5" square tube with ruffstuff crossmember mounting kit w/ greasable bushings. Gm 1 ton master cylinder, new brake lines ran.
Dana 60 front 4.56 w/ limited slip. high steer arms. Drilled for 3/4 heims. Drag link & tie rod chromoly w/ 3/4 heims. Sky's 3/4" less drop pitman arm also drilled for 3/4 heim. DIY shock mounts, Toy rears mixed spring pack 7 leaf. Trailgear spring mounts & Skys fullwidth shackles. Bilstein 5125 14" shocks.
14 bolt rear 4.56 detroit. Disc brakes w/ Ruffstuff plates. DIY pinion support tied into truss. Truss is 1.75" .250 wall tube with 1/4 plate. Great Lakes Diff cover, drain plug, countersunk bolts, tab for tie in mount to truss as well.
1/4 Ellip rear springs from 57" Fords, 3/4 heims on shackles. All ballistic brackets. 1.5" .250 wall upper links & 2.25 .500 wall lower links with all ballistic joints. 5150 rear Bilsteins 12" travel
Square front driveshaft. Brand new rear shaft. Front and rear bumpers & sliders, shock hoops. Ford 20 gallon tank. with a swing drop mount. 2" 8 lug spacers.
All stock interior with a Sunroof!!
40" MTR's mounted on H2 wheels
Located in Las Vegas
$10,000 obo 702-326-9249
any questions or pics just ask. Selling because I have too many rides and my dually is not selling so something has to go.
The statistic on sanity is that One in every four is insane, Think of your three best friends if they're ok then its you.
bigarms23
how much tread do the tires have left
Lizard_lips
thegoofster21
damn i wish i had the money
Quote from: crawlerdad on October 08, 2009, 08:21:17 PM
Any guy who takes his woman wheeling enjoys her. A woman who is owned is left at home to cook, clean, and keep beer cold. So if this offends you you should stop looking and go have some tacos.    :rofl2: And a beer. If your old enough.   :beerchug:   :beer:
04 Tacoma 33s http://board.marlincrawler.com/index.php?topic=61454.0
jmoffroad.com
gtoyonrocks
That's pretty sweet.... Do you run anything but full widths in your trucks? I have seen three or four trucks you have built and I want to say they have all been full widths.
Lizard_lips
Not anymore. I can't handle anything but the big stuff on my truck. Its so easy to build now that I have done them lots of times. Its way more fun too.
gtoyonrocks
Yea??? I have a set of one tons under a k5 blazer. I was thinking of canibalizing them for a toyota build and turning the blazer into a 2wd.
Lizard_lips
Its way easy and more fun with tons on it. I don't think I will ever run anything but them now.
bigarms23
Lizard_lips
Lizard_lips
Alright... I need the money more than ever now so make an offer on this thing. I need to move it asap.
Lizard_lips
bigarms23
do you have different gears that go rith say a set of 513s or 538s just curious
Lizard_lips
No, I never got around to changing the gears on it. I wanted to go 5.13 since that is what I had on my last trucks and they are nice. That was the next thing on the list to do but things changed now and it has to go.
bigarms23
Lizard_lips
jojoya
BUmp for a sweet runner awesome ride man
Lizard_lips
bigarms23
Lizard_lips
Lizard_lips
hilux-1983
Got any better pics of the rear suspension articulating?
Lizard_lips
I don't right now. I can get some this weekend. I will see what I can do.
bigarms23
found this on pirates
Lizard_lips
Here you go. Mall crawlin at its best even with the street rollers.
Yota Rolla
#25
 :biggthumpup: :thumbs: bump for a badass runner
82 locked,geared,cased,caged daily
Lizard_lips
ToYocRawleR
Got any pics smokin those donuts?
Rigs:
05 F-250 Powerstroke
93 RunneR ...Build-up  http://board.marlincrawler.com/index.php?topic=85644.0
fortysixandtwo - I drove through Dunsmuir once I dont think anything there is "super nice"
Just kidding man. I guess there is, its your bed
yota4x4sc
that front bumper looks sick!  i wish i woulda thought of that while i was making mine
:usa: 92 xcab, full width, 39.5 boggers, beadlocks, 60 f arb 5.86s , 60 r spool , duals, 4.7 rear... 3.sl0, bobed , all pro 6 inch leafs f and r :usa:
joey0712
Quote from: yota4x4sc on October 09, 2010, 02:13:09 PM
Have u been drinking??? Ive seens like 20 threads you have posted in today??? WTF
91 Toyota High pinions f&r.
