93 4runner lift
Started by JUGGERNAUT, December 15, 2004, 03:15:11 PM
JUGGERNAUT
My buddy just picked up a 93 runner and wants a 4" suspension lift. He wants the cheapest lift he can get, what do you guys think would be the lift for him. He wants to find one $500.00 or less.
BCD
None that I am aware of for under $500... but he can crank the torsion bars in the front and add a coil spacer in the back for about 3ish inches of lift. Even with shocks it would be cheap.
JUGGERNAUT
He wants to squeeze a set of 33's under it and he plans on trimming the fenders for a little extra room. It has 31's on it now but I don't think you can get enough out of the torsion's for 33's. Can you?
BCD
yeah I've seen 33's on a setup like that, no fender trimming either because you really won't gain much articulation or performance, mostly just aesthetics and ground clearance is all that will be gained. If it sags a little in the back now, like most of them do you can also level it out in the process.
mudaddict
U can fit a pair of 33's on there with out a lift thats what i ahe right now the only thing is u have a little bit of rub in the front when u take sharp turns! very tillte trimming is needed! i jsut picked up a 4 in suspension lift made by procomp and that ran me a good 1500 good luck with the cheap under 500 dollar suspension lift because it is the ifs system. if his runner is a manuel he can get a body lift for about 150. If its an auto like mine is he has to get a suspension. I hate my auto!!
I work At
All Pro Off Road
mudaddict
Does anyone know how long or how hard a install on a ifs suspension lift is?? im gonan do mine soon hopefully and im trying to find out if its hard and how long it takes!
I work At
All Pro Off Road
raybie
i have a 90 runner that i put a 4" lift on.  it took 2 of us about 16 hours with a car lift.  of course part of that time was spent trying to figure out what was what and dreaming about other projects :idea: .  i bought a used trailmaster lift for the front and a used procomp for the rear with 2.5" aluminum spacers.(found them on pirate4x4)  had about $600-650 in it once i bought new shocks.  then i got sick of the front always getting beat out of alignment  :smack:  and the rear tearing the upper control arm mounts off the axle housing  :smack:  and did a sas and chevys :thumbs: .  $1600+/- in the sas and $100+/- in the chevys.
BLACKDOG
try to find a used lift, that would be the best way to go for cheap, or a body lift, but you wont get 4 inches.  I owuldnt go more than 2, but i have a 3" on a pickup right now.  Crankin the torsion bars makes for a pretty rough ride, the lift is just better to do in my opinion.
              -Ronald Reagan
JUGGERNAUT
Thanks for the info. I've been trying to talk him into a SAS but he doesn't want it. We're going to crank up the torsions for now and go from there.
surfindave
hey Guys for another lift in the front you can always go the balljoint spacers and crank the tbars
less angle on the cv and a bit more wheel travel out the front.
Go with 2" coils at the rear with a coil spacer if you go too high the pinnion angle gets a bit too much
4" is realy the max then you need the best length rear shocks rancho9009 for the most travel.\
Hers a link on the Ball joint spacers
http://www.sdori.com/SDORS%20spacer%20page.htm
Dave
SWAMPER
Juger tell your buddy about a body lift...I have one and i dont feel very tipsy like some say and and Mudadict I would recomend not getting Pro-Comp and getting a BDS lift I heard that with pro-comp since its cheap you wear out a bunch of stuff...quick :twocents:
robinhood4x4
The standard recipe for fitting 33s under a 2nd gen 4runner is:
1.  crank up tbars or do ball joint spacer
2.  Downey 1.5in coil lift in rear (or any 1.5 inch lift to level it out)
3.  Roger Brown 1" body lift
4.  Minor fender trimming.
Lots of people have this setup and can do trails like the rubicon and dusy (with other mods).
For more lift in the rear you can go with FJ80 rear coils for a 3-4 inch lift.
Quote from: cruzilaWell, if the ideal of excluding the lesser equipped (stock or otherwise) is accepted... there is no fundamental difference between that and a Sierra CLub ideal of exclusion. If we cannot embrace the 4wheel users as a whole. We are not fighting for access. I cannot be that shortsighted
mudaddict
If u just get a 1 or 2 in body lift you can fit a pair of 33's nicely underneath it! its also depending on if its a stick or auto if its a stick your all gravy for a body lift if not suspension lift is the option or the ball joint spacers! my 33's have very little rub and i didnt do much to fit em either everythign is how it was wheni had a set of 31's under it!
I work At
All Pro Off Road
surfindave
Hey Guys
Whats the problem with doing body lifts on Autos?
I have a Auto tho it does have a divorceable transfer case is this the prob you guys have that your auto is not divorceable?
I had no problems goin to a 1" body lift then when i went 2" i just ground the tunnel for the low range lever.
Be interesting to know why .
Thanks Dave
mudaddict
I havent gotten an answer why i have been woundering the same question! everywhere i go and everyone i talk to about it when i say i want a body lift they alway end up asking me if its an auto or man and when i say auto they jsut say oh cant get it! so i would like to knwo the answer to that question also!
I work At
All Pro Off Road
robinhood4x4
SWAMPER
You still need the bracket for a 2" BL trust me you wont notice it in normal driving or H4 but when you shift in L4 you got some thumping going on...therefore you need the A/T bracket.... I know cause I have it :yupyup:
raybie
QuoteThe standard recipe for fitting 33s under a 2nd gen 4runner is
bolt them up.  :thumbs:  I ran 33x10.5 TSL's on mine with stock suspension and no rubbing.  rims, i think, are 15x7 with 3"?? backspacing, they were off my buddys 84 truck.  no fender trimming needed, no body lift needed, no lift, nothin.
reklund5
Just SAS it.  Its way cheeper in the long run!  :eyebrow:
mudaddict
Ya well for ifs a brand new pro comp lift aint cheap truct me put a FAT dent in my pocket!! Well i have never herd bad things about pro comp so i went with them! well we shall see when i get it on any everything! Ya i wish i would have sas mine first but oh well! Ya im running 33's on mine right now i get little rub and im stock!
I work At
All Pro Off Road
BLACKDOG
Quote from: SWAMPER on December 19, 2004, 08:30:17 PM
I havent had any problems with my Pro-Comp :dunno:  Mabye I have been lucky, or mabye Swamper is  :smoke: sumthin.  I've been really happy with it, 'cept for the fact that I want a SAS
:beerchug: jk swampy
              -Ronald Reagan
MUDJUNKY
i have never had any troubles with a pro comp lift but ive got a straight axle
"I avoid myspace like the devil himself...  Nothing good can come from having teenyboppers and childmolesters mixed with emo morons hanging out in one place...." white trash.
