front hub issue
Started by spuds015, May 31, 2010, 08:46:54 PM
spuds015
truck is the one in my sig. i discovered today that when i lock the manual hubs and drive regardless if im in 4 hi 4 lo or in 2 hi the truck feels like im driving on a coblestone road. when i unlock them it goes away. does this mean my front hubs are toast? :-\
'81 pickup 5vzfe, r150f, 35's, welded 5.29's, f150 rear springs, Rears up front, TG dual adapter w/ 2.28's
junya92toy
Maybe it means the front driveshaft is toast.
spuds015
most definately the fron drive shaft. cv's spind fine by hand but the driveshaft binds in one position. so my next question is whats a good upgrade? i plan on doing a 3in lift w/ 33's so i can learn to wheel it better before i go to sas.
axled89
go with another stock one for now.   you'll change it when you do the sas. anyways.
i love oregon wheelin.
madmax886
x2
put your ifs through the ringer so yo can compare it to the sas... world of difference almost have to re learn how to wheel
axled89
just start saving for the sas now screw the shaft.   putting money into the ifs is a waste.
Except he wants to be able to wheel it now  :shake:
axled89
 :slap: yes i know.  i understand that.
spuds015
#8
as it is still a dd i need 4wd during the winter but there's no excuse for driving a broken truck. i talked to a buddy whos the car/truck guy (i know motorcycles) and he suggested it may just be the u joints, so ill check those but with 228k and beating on it all through high skool i think it would just be better to replace the whole thing.
2manytoys
Spuds,
I think your bud's right about the u-joint. Had the same thing happen to my 86 4Runner. I checked the drive shaft for sloppyness and it was tight so I missed it at first.
It was actually a siezed u-joint bearing on one side. Made it wobble bad.
spuds015
even if he is right a brand new one from kragen is only $75 so may as well R&R
