Author Topic: AUSSIE LOCKER in V6 REAR (UPDATE)  (Read 1642 times)
2manytoys
  • Turtle Points: 490
  • Male Posts: 583
  • Member since Nov '09
« on: May 28, 2010, 06:46:40 PM »
I haven't seen any real feedback about the Aussie V6 model XD24930 yet. I just started installing one so I thought I'd share.
I put a 4cyl Aussie in my son's truck a couple years ago and it still works great so I thought I'd get one for my V6 rear diff.
Installation is pretty straight forward and it came with good, easy to follow instructions. They have specific tolerances that must be checked and within specs.
Mine are on the tight side (just below minimum) and I was concerned so I contacted Torq Masters by e-mail. They responded right away and had one of their techs call me at home. After speaking with him I was assured it would be OK to run. To loosen it up, I would have to either come up with some thinner side gear thrust washers or have them machined about .005. The ones I have are .038.
Anybody else run into this or know if Toyota has thinner thrust washers? If you get one and it is on the tight side I would still check with Torq Masters before installing it just to be sure you don't void your warranty.
I was also putting in a solid pinion bearing spacer and found my pinion bearing beginning to pit so I'm waiting on a diff setup kit. Once I get it installed I'll update this post.
Got it installed..........FINALLY!  Working good. No problems unlocking with the tight clearances. About the same as the 4 cyl version as far as feel and noise.
« Last Edit: Jun 16, 2010, 06:39:20 PM by 2manytoys »
ZUK
  • Turtle Points: 9
  • Male Posts: 168
  • Member since Nov '02
    • ZUK's Gear installs
Re: AUSSIE LOCKER in V6 REAR (Some Comments)
« Reply #1 on: Jun 04, 2010, 08:33:57 AM »
Good to hear. I installed a V6 Aussie also for someone else. I was pleased that it came with some measurements unlike the Lockrite version. Mine was a bit on the tight side also I recall. Keep us updated. ZUK :beer: :beer:
           www.gearinstalls.com
2001 White Xtracab Taco 3.4L Auto TRD
88 Runner/V6/auto/31"/5.29gear
2manytoys [OP]
  • Male Posts: 583
« Reply #2 on: Jun 05, 2010, 12:54:06 AM »
ZUK, Thanks to your gear install pages I got my diff together today. I have built a lot of diffs but all huge Caterpillar diffs. This is my first Toyota and I really needed some specs. THANK YOU!
I'm pulling my R151F in the morning so I can rebuild it. Once I get that done I'll test the Aussie out and update this post.
Last post Jun 29, 2004, 12:07:41 AM
by Skinny_Pedal
Last post Jan 09, 2005, 02:59:47 PM
by lowgeared
Last post Jun 08, 2006, 08:23:43 AM
by yodaboy4life
Last post Nov 02, 2007, 12:28:04 PM
by 46&2
Last post Aug 13, 2008, 09:14:17 AM
by THK Matt
