RUF pack for a DD?
Started by DFWFO, May 12, 2010, 09:10:01 AM
DFWFO
Im wanting to do rears up front on my DD, bad idea?     85runner
I have my stock rear springs, plus the 4in rears im running are about to be pulled off. I think they are 4in, they were laying in my buddys back yard for a while, decided to bolt em up, taking out my blocks. I dont know what they are, so i dont know what the weight rating is. So im getting new springs for the rear, anyways.....
Im a noob, I dont know what pack would be best for a dd. Should i just build a pack from what i have?
:dunno: :dunno: :dunno:
All Im lacking is a flux capacitor and the ability to hit 88.
-Jake-
I run RUFs on my DD no problems at all.  I added a couple leaves from another pack though.  I have a 5 leaf pack
NorCalToy
Im running a stock RUF pack on my DD and its works fine, although its a little soft so Id definelty add a leaf or two.
:flamer: IFS
do you have the stock pushpull steering??  because if you do you CAN NOT use ruf.   Rears u f require high steer
bleakhorizon
Quote from: 79coyotefrg on May 12, 2010, 10:42:07 AM
actually I ran Rufs and push pull for a while. never had any problems. I had a j arm with a flipped ball. and I shortened my steering arm.   of course it had nasty tourqe steer when braking.
Those are some huge welds!
Tillamook, OR
DFWFO
I already have hoops and shocks, but i dont have an ifs box or histeer yet, Im moving as fast as my finances will let me. But i will def be running histeer with the ruf.
What about the front hangers? I've read a few people have had problems with approach angle. Is it really necessary to hang em that low? Again, Im a noob.
minicrawlin
 :offtopic:   but i love your signature DFWFO
"All Im lacking is a flux capacitor and the ability to hit 88"
theres alot of info on RUF's all over the net, i suggest doing a little research man! and although your hanger may catch, having your axle moved forward should help your approach angle, so its a balance between the two i'm guessing!
the rocks Rock in South D SON!
DFWFO
I have found alot of info online plus i have the toy faq from pirate to refer to, but the stupid questions i have dont really get answered, If i dont find what I need im going to a junk yard next week and pullin some used springs off something useful, need to fix my a/c anyway, thanks guys
until you get highsteer pull your stock front packs apart and throw everything but the top 2 leaves away, then tank a set of rears, pull them apart, toss the flat load leaf, cut the ends off the top two and install them under your top two front,  you'll get 3 inches lift or more and be able to use stock steering
DFWFO
so i can build a pack out of my front and rears? wouldnt that leave my wheel base the same length?, im not doubting your sugg, just asking
muddywaters
The RUF faq on pirate answers just about every question you could ever have for the swap.  most people, especially on pirate, do not answer noob question when there is a faq with a wealth of info.  i would look at that and at the chevy rears swap faq b4 posting again on pirate.
Im like Hugh Hefner minus everything good about his life.
DFWFO
Ive been looking at the pirate faq for a while, I stopped asking questions over there a while ago. There are too many noobs answering questions, and they usually have no idea what they are talking about. But there is some grrreat info on pirate it just takes alot of searching, but there faqs links are starting to be broken alot, lots of missing links.
79toy20r
Quote from: DFWFO on May 13, 2010, 09:20:44 AM
yea your wheelbase would remain stock. He's just saying that to get you some lift until you can get your highsteer.
79toy20r
this is my approach angle with RUF and 37's with 2" drop hanger
DFWFO
Is that what you'd call a negative angle? what size shackles? thats exactly what i want to achieve, i like that approach  :biggthumpup:
minicrawlin
negative approach angle is when the tires pretrude beyond any frame and is the first thing to hit anything, like a wall or whatever you know. it's the coolest thing ever!! ha ha
DFWFO
Can i install hoops and shocks now, then about a month or so do RUF? or will i have to cut my welds off the hoops and move them forward with the leafs?
or just install the hoops 2in forward
Jared88
if you instal tham forward now...depending on your mounts....it'll angle the shocks a bit. I'd probably just go ahead and throw the shocks on now...and then cut the hoops, smooth out the frame, and reweld them farther up.  :twocents:
1988 standard cab, SAS, 5.29's....and a few other things  **SOLD**
1958 Volkswagen Bug, 2276cc, close ratio gearbox, quite a handfull.
