Converting a york compressor to air for on board air
Started by dgrant71, April 28, 2010, 05:25:22 PM
dgrant71
Converting a york compressor to air for on board air, does any one know anything about this? I have herd different hings about it and wondering how to convert and where to start or if there is a better way to run on board air.. Thanks
OOPS
A lot of good info here.
http://www.kilbyenterprises.com/kits.htm
A york will give you more air then you will ever need if set-up right. If it is for a 22r without AC I have plans for a very simple mount.
dgrant71
OOPS
Here are the plans for the mount. I did not draw these up or use this mount. It was posted on PBB a couple of years ago and the poster said it worked. The last picture I added a comment to give it some adjustability.
dgrant71
Awesome!!! Thanks, that will help out ALOT, i believe this bracket is like $150 to buy. Thanks!!!
GNasty 82
Although it's a heep site, it's a very good write up on everything to do with making a york into OBA except for mounting to Yotas.
http://www.jedi.com/obiwan/jeep/yorkair.html
82 Toyota SR5 Pickup
  Marlin Dual Ultimate
  Front 5.29 LC HP Elocker
  Rear 5.29 Grizzly Locker
  BFG 37" KM2s
  Custom rear frame and flatbed
  Propane Powered.
Build Thread:
http://board.marlincrawler.com/index.php?topic=64521.0
Quote from: Toymin8r on July 19, 2010, 02:18:05 PM
"The two enemies of the people are criminals and government, so let us tie the second down with the chains of the Constitution so the second will not become the legalized version of the first."-Thomas Jefferson
