Spcl Construction
Started by Ferg, December 09, 2004, 08:47:27 PM
Ferg
'80 short bed frame
'85 Xcab, bobbed bed
'92 4.3L V6
W56 w/dual cases 2.5/4.7
4.10s w/33s
davidt
how hard was the cab swap, I dream of being able to lean my seat back
FATB0Y
Ferg
Quote from: davidt on December 11, 2004, 12:32:29 AM
Had to raise the floor behind the seats back about 3 inches due to mid crossmember.  Body frame horns had to be cut off and repositioned on opposite sides to line up w/body holes.  Front core support body mounts do not line up, had to make new ones.
Over all, I would not do this again.  Learned a lot but too much work for an inch or so leg room.  I get about the same amount of stuff in the cab as I could with the reg cab.
Recommend buying a 4Runner instead.  Same wheel base, loads of cargo room,  and way less hassle.
I think it is probly easier to put a extra cab on a 84-88 regular cab frame.  It was pretty easy for me and james.  Pretty nice setup truck.
NUb
Quote
Quote
The key is to swap a 3rd gen cab on to a regular cab frame, just move the rear mounts. Pluss you get way more room and the bling factor.
Jeff
I would Take my truck offroad but then it would get dirty
94 exta cab 84 frame
4.88 electrics w/duals and 35's
Tacoma bed?
