off camber
Started by Jake K, April 09, 2010, 11:23:09 PM
Jake K
 :confused: Hi all. i just bought an 84 toyota and the only real problem it has is that the  front knuckles seem to be off camber.  the front tires were worn all lot worse on the inside. i was wondering if anyone has seen this and has some possible diagnosis'? ???
junya92toy
Its more then likely the toe is off.
Jake K
how do i fix it? the toe can be fixed with an alignment cant it?
junya92toy
Yes, thats the only adjustment you can make.
84t0y
also the trunnion bearing could be completely shot and that would cause the wheels to be tilted.
if so then you would need to buy a knuckle rebuild kit, i would also suggest a wheel bearing kit as well, you can buy them here on this site.
Or and I don't really want to say this, the housing could be bent. If it were jumped at all it will bend the housing at the end of the bell. If bad enough it should be very visible.
