Introducing Marlin Crawler Weekly Specials!
Started by BigMike, April 02, 2010, 08:58:55 PM
emsvitil
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
Well.... We were trying to get some new products released by 4pm today but it didn't happen. So we are gonna run the Billet High Steer arms for another round :thumbs:
New products coming next weeeeeeeeeek!!!!
GNasty 82
Maybe some tax return specials in a month or so on these so called new products   :sly:  :phone:
82 Toyota SR5 Pickup
  Marlin Dual Ultimate
  Front 5.29 LC HP Elocker
  Rear 5.29 Grizzly Locker
  BFG 37" KM2s
  Custom rear frame and flatbed
  Propane Powered.
Build Thread:
http://board.marlincrawler.com/index.php?topic=64521.0
Quote from: Toymin8r on July 19, 2010, 02:18:05 PM
"The two enemies of the people are criminals and government, so let us tie the second down with the chains of the Constitution so the second will not become the legalized version of the first."-Thomas Jefferson
Rock4Runner
There are not victory without sacrifice!
Quote from: BigMike on January 14, 2011, 09:05:03 PM
82toycrawler
Wow those are some awesome, neewly released spring perches.
82 Toy, Ultimate, 4.88s & 37s
#157
This week's special item is the brand new fully built 4cyl Spartan equipped differential!!
Product link: http://www.marlincrawler.com/differential/complete/spartan-equipped
Regular price: $749, Sale Price: $636.65! 15% OFF, SAVE OVER $100!!
Our complete differentials include the following:
  • High Quality Yukon Ring and Pinion Gear Set
  • Heavy Duty EcoSeal
  • Heavy Duty Five-Pattern Flange
  • Heavy Duty Solid Pinion Spacer
  • Brand new Toyota bearings
  • 2 Low Profile Magnetic Drain Plugs
Additional notes: The Spartan Locker is an automatic "drop-in" locker, meaning that it installs into your factory carrier assembly rather than replacing it. Like the Grizzly, the Spartan Locker is an improvement upon older designs. Made in the USA, it features a revolutionary spring-and-pin design that makes it stronger than other drop-in lockers. Additionally, it features oversized pins (larger than the Lock Right) while the couplers and drivers are made from 9310 chromoly steel to compensate in strength. Due to its compact and simple design, the Spartan rivals more expensive lockers. This is an excellent upgrade to get the traction you really need!
Offer expires Feb 4 at 4:00pm PST
:turtle:
This week we are offering our new Gasket and Seal rebuilt kit for 25% off!
You cannot find a more complete gasket set anywhere. This is a great rebuild kit using all OEM Toyota gaskets and seals. We've also included our Heavy Duty transmission EcoSeal output at no additional cost!
http://www.marlincrawler.com/transfer-case/parts-upgrade/gasket-and-seal-rebuild-kit
This week's Special Product is our 30-spline Chromoly Front Output Shaft Kit! Featuring up to 23% larger diameter than stock, this is hands-down the strongest front output shaft on the market.
Get your paws on this kit at 25% off retail now through March 11th!
Link to product page: http://www.marlincrawler.com/transfer-case/parts-upgrade/30-spline-chromoly-front-output-shaft
Product comparison and detailed instructions available online.
twistedtoy92
This week's special product is our FJ80 Knuckle Service Kit!
This high quality kit is complete with new wipers, felts, gaskets, lock washers, inner axle & bearing seals, hub gaskets, High Quality Japanese NSK knuckle bearings and two of our FJ80 Heavy Duty EcoSeal inner axle seals!
Take advantage of this limited time offer and save 25%!
Product link: http://www.marlincrawler.com/axle/front-axle-parts/knuckle-service-kit-fj80
yoshaleng
Hey BigMike, I know it's over with already but can I still get this deal on the 30-spline Chromoly Front Output Shaft Kit? Please let me know before this weekend.
This week's special product is our Heavy Duty Transmission output EcoSeal! Your choice of either 21- or 23-spline, we've got em all on sale for the next week at 15% off! This is the best transmission output seal on the planet with the same great features that made our Heavy Duty Inner Axle seals world famous! Keep your clutch dry and your transmission safe today!
Product link: http://www.marlincrawler.com/transmission/parts-upgrade/heavy-duty-transmission-output-seal
This week's special product is our Top Shift Conversion Kit! Now is your chance to save 15% and convert your forward shift case using our high quality billet and heat treated parts! Comes with double-rolled HD pins with forks designed to fit our 4.70:1 gears without any modifications!
Product link: http://www.marlincrawler.com/transfer-case/shifter-parts/top-shift-conversion-kit
#165
We now have both standard and rotated Xtreme Duty MC07 Adapters ready to go! This is a very exciting time for us because we've been waiting for the standard XD versions and now they are here! So to officially kick the Xtreme Duty Dual Case Adapter off, we are offering either kit at 15% off for 1-week!! This is a GREAT deal on the strongest Toyota dual case adapter in the world!!
Exclusive Xtreme Duty features not found anywhere else:
  • Double Roller Maximum Capacity Main Shaft Bearing to minimize axial flex
  • Chromoly Coupler for maximum spline strength and durability
  • Oversized Heavy Duty Cage Bearing to combat extreme temperature and pressure
  • Radiused Coupler for increased pocket bearing oiling
  • Heavy Duty Plate Webbing for increased rigidity
  • Thrust Washer Lock System to prevent wear and debris
  • Shelf Oil Passages to capture and transfer more oil
  • Multi-bolt Retention System designed for optimum load spreading
  • Japanese Industrial Standard Heavy Duty Fasteners
  • CAD Optimized Light Weight Adapter Cutouts to increase oil capacity and save weight
  • Unique Margasket to simplify installation
  • and a complimentary EcoSeal Transmission Output Seal, the most versatile and effective output seal on the market.
Product Link: http://www.marlincrawler.com/transfer-case/dual-adapters/1979-95-gear-drive-mc07-xd
EDIT: Updated photo
KRT
Awesome! I have been waiting for these to go on sale!
NorCal TTORA
89 PU SAS 37" Iroks
07 Taco
KDXSR5
Ah hell, I have some decisions to make now.
KDXSR5
#168
Quote from: BigMike on April 01, 2011, 06:58:53 PM
It says here that BOTH KITS are 15% off. On the website it says that the non rotated is the only one on sale. Will you honor the 15% for the rotated cases that is posted here?
EDIT by BigMike: I updated the picture in my quote
spc mike
I will be there first thing Monday morning! :clap:
spc mike
Quote from: KDXSR5 on April 03, 2011, 03:27:35 PM
If you put the 10 degree in your "Cart" it will ring up at the sale price. I just tried it.
KDXSR5
Quote from: spc mike on April 03, 2011, 03:30:41 PM
I just did too.
The sale price applies to both standard and rotated Xtreme Duty versions. Both options are configured to have the same sale price :thumbs:
KDXSR5
Quote from: BigMike on April 04, 2011, 11:23:28 AM
Sweet! I put my order in last night for a rotated 21 spline adapter. I sure hope it ships out today because I would like to see it before the weekend!
This week's sale item is our USA-made High Steer Kit. Complete with amazingly strong Billet USA Steel High Steel Arms, USA DOM drag-link and tie-rod bars, special pitman arm and massive FJ80 tie rod ends, this kit doesn't disappoint. For 1 week only we are offering this kit for just $349! That's nearly 20% off!
Additionally, if you purchase our Competition Series 25mm Pin Upgrade Kit with the High Steer Kit, we'll knock off $50 bringing the combined savings to over $125!
Check it out! It's a fine time to upgrade your steering system!!
Hilux Kit: http://www.marlincrawler.com/steering/high-steer/high-steer-kit-hilux
FJ40 Kit: http://www.marlincrawler.com/steering/high-steer/high-steer-kit-fj40
FJ60 Kit: http://www.marlincrawler.com/steering/high-steer/high-steer-kit-fj60
25mm Upgrade Kit: http://www.marlincrawler.com/axle/front-axle-parts/25mm-steering-pin-upgrade-kit
Ok guys,
We've got something a little different this week. Back by an overwhelming demand, we are putting our MC07-XD Kits up for another weekly sale! This repeat offer of 15% off is ONLY good until the 22nd, after which we will be changing the regular retail price.
This is your last chance to act now! We won't be putting the MC07-XD on sale for a while!!
Product link: http://www.marlincrawler.com/transfer-case/dual-adapters/1979-95-gear-drive-mc07-xd
Take advantage of this last sale offer and get Crawling by summer!!
Peterbuilt84
Quote from: BigMike on April 15, 2011, 05:32:15 PM
Are you going to raise the regular retail price after the sale? :dunno:
BikerTrash
DANGIT!!! missed out on the highsteer >.<  oh well.
There is a fine line between clever and stupid, I just wish I knew when I crossed it.
84 4runner
02 Suzuki V-Strom
95 Honda 1100C1
06 Ram 2500 4x4
(please note, listed in order of preference)
Cheesemaker
Bigmike, you've got an incoming PM.......
Quote from: Peterbuilt84 on April 15, 2011, 05:47:31 PM
they cant keep the old prices when EVERYTHING has gone up in cost because of the economy/gas prices.
