Tranny is assembled and working again!!!! WHOOT WHOOT!!!!
Started by Sluice Box Hero, December 06, 2004, 06:19:29 PM
Sluice Box Hero
just reassembles my G54 after a week of hunting down at 14mm allen wrench, was to tight when it broke loose i killed my hand on the frige (yes, im fixing it in the kitchen.  . )  anyway, i was able to put it back together tonight.  it had been stuck in reverse, well, i resealed it (form a gasket).  then i replaced most of the bolts, and bilts the xcase up as well (more form a gasket).  anyway, its styling with those pretty new pink  :stopit:  :stopit: bolts.  anyway, it made my week, so you all have to hear about it.
Later,
Callen
"You know that feeling right after you take a huge dump? . . . . Awesome"
-Cartman
camo89
glad to here your getting it all ready hope every thing gose smooth
mopar parts
Sluice Box Hero
gunna bolt up the slave cylinder tonight, and try and track down a clutch fork in the next few days (anyone got one you wanna give away?  ill pay shipping)
Callen
-Cartman
Marlin
I have many, many forks in stock.
What size shirt do you wear.
Make you a deal. Buy a tee shirt, and we will slip in a fork for free.
Give us a call, it will be sent tomorrow by UPS. Two days ground.
559 252-7295
Marlin
Sluice Box Hero
Marlin,
consider it a deal.
ill call tomorrow afternoon, who should i ask for?
Callen Myers
2944 Helgeson Lane
Grants Pass, Or 97527
-Cartman
Sluice Box Hero
#5
Marlin, you sir are the man
Called this afternnon, talked to marlin himself, awesome comsumer service, and awesome deals!!!!
I will be ording again from you that is for sure!
Callen
-Cartman
Marlin
Callen, thanks for the kind words. :thumbs:
Sent the fork, 2 clips, 6 pressure plate bolts, pilot bearing, and release collar with bearing pressed on today.
We also included a metal clutch alignment shaft and a TITS shirt.
Thanks for taking me up on my offer.
Hope everthing goes together as planned.
Marlin
Sluice Box Hero
i cant wait to get this swap going!!
hey marlin,
you didnt happen to stick a few sticker in there with that shipment did you???  i posted up about the 6" on the free sticker thread that will go nicely on my DD, but, i also saw you all have a 12" one that would fit the Toy perfectly.  if not, not a problem, next time i order from you ill remember to say soemthing.
again, thanks a lot for the deal :beer:, you are the man, plain and simple.
Callen
-Cartman
