Parking brake
Started by BLACKDOG, December 06, 2004, 01:22:28 PM
BLACKDOG
My parking brake cable has snapped several times.  I have fixed it before, but i have no interest in paying for a new cable (32 bucks was the cheapest).  The junkyards around me dont hav many toyotas, so i am out of luck there.  Is there another way of putting in a parking brake>?  I have heard of the driveline brakes and suck, biut i am not sure what thse consist of.  Right now, I use a brick :smack:
              -Ronald Reagan
kyle_22r
could always leave it in gear :dunno:
BLACKDOG
I do that too, I am just talking about on hills and such when the weight of the truck overpowers the gear
              -Ronald Reagan
Yota4life
Blackdog where do you buy your e-brake cable from? My cable snaped and i need a new one.
BLACKDOG
I didnt dig to deeply, I just went and felt out the prices a little.  Dealer was $65  :slap:
Kragen was $32 and i think autozone was about $40.  Both kragen and autozone would have had to order it.
For the temp fix, I got the cable from Ace hardware,  and splices the connectors at the rear onto it.  I took the lead ball and cable off an old bike brake cable, and spliced it to the cable in the front, and put the lead ball in the e brake handle.  It worked alright, but there isnt much room in the handle slider for the splice, and it keeps catching.  Tat is where it keeps breaking.  If yours is broken under the truck, I would just splice it with the cable splicers you can get at any hardware store that carries that type of cable I beleive it is called aircraft cable?  They just clamp on around the ends, and you crimp them down.  I just didnt think that 35-40 bucks was worth it.  I think the cable and the splices cost me something like $8.
              -Ronald Reagan
MidgetMike
#6
My buddy is into hot rods and has a line lock in his car, he uses it for brake stands at thhe track to warm up his tires without fryin his brakes. It's a hydrualic lock out u put between your master cylinder and front rear or both brake lines when you need a parking brake press the brake pedal and pull the switch and your set and this one won't break.  :thumbs:   :twocents:  :turtle:   Ho ya I got the same problem and I don't want a driveline brake either  :nonono:
And I'm pretty sure he told me summit sells them parrt # about 4 down  BMM-46076 69 bucks but the last parking brake cable youll buy  :beerchug:
http://store.summitracing.com/default.asp?target=esearch.asp&N=110&Ntk=KeywordSearch&Ntt=line+lock&x=19&y=8
Willy Mammoth
Willy Mammoth
Need to be careful with line locks, they arn't for long term use. I burnt mine up trying to use it as a ebrake.
Willy Mammoth
Hey Flip Flop, Whats that black spot under your avitar's bottom?
MidgetMike
No one likes the line lock eh? I got 2 brake cables in Auburn Ca east of Sac make offer!
BLACKDOG
              -Ronald Reagan
MidgetMike
15 and you got a deal  :thumbs: you come and get 1
MidgetMike
Quote from: Willy Mammoth on December 07, 2004, 04:28:48 PM
How did it burn  up it is supposed tobe a hydralic lock i know it is electricaly accuated but it should be done with the electricity until you push the button again but I don't know so any knoledge is much appricaited. sweet build thread your garage kicks a^%  :turtle:
BLACKDOG
what is it for??  I forgot to metion i had an extended cab truck
              -Ronald Reagan
Flip-Flop
Quote from: Willy Mammoth on December 07, 2004, 04:31:56 PM
It's a shadow of me bottom.
BLACKDOG
I think Calvin has the squirts  :puke3:
              -Ronald Reagan
BLACKDOG
hey, mike, sorry i forgot about this post.  YOu dont happen to stil have those parking brake cables do you??  If you do I would like to take one off your hands
              -Ronald Reagan
awhotrods
OK, I have a question for everyone, I put a wider rear axle under my 82 4WD, will the stock e-brake cables work, or do I need to get the 86up rear ebrake cable to make it work?
BLACKDOG
i dunno, see if it stretchs that far, if not, you gotta switch
              -Ronald Reagan
MidgetMike
Yeah from the arm to the axle let me know if you want it
BLACKDOG
yeah you gonna be aruond on Sat.??  I am going boardin and i will be going through auburn
              -Ronald Reagan
MidgetMike
Quote from: blackdog on January 11, 2005, 08:14:46 PM
Call me on your way home I live near IN and Out I'll bring it to my apartment actually I'll IM you with directions to my work incase I'm not home cause I'm gonna run up to the snow
Volcom
Quote from: awhotrods on January 11, 2005, 05:20:03 PM
I've got the same question, anybody have an answer?  :help:
84 4Runner
Marlin Dual Ultimate crawler
Marlin high steer
TG springs
109" wheelbase
Addicted Off Road
BLACKDOG
Stretch it, and see if it goes that far.  You might have to  adjust the e brake assemblies on the wheels, but it might work
              -Ronald Reagan
