Head Gasket/Timing chain Questions
Started by HFCRAOffroading, December 05, 2004, 10:21:18 AM
HFCRAOffroading
What make, year, model was the Head Gasket Recall for?  Was it the 22re or the V-6 engine?
When is it recommended to change the Timing Chain and Guides?
I am looking at buying a used Yota for a DD and a little wheeling,  just kinda like to get some background info before I buy.
    Thanks in advance!
         Jack
v6 3.0  bad headgaskets,   22r 60000 miles, replace with metal from various sources
HFCRAOffroading
If the 22r is good for 60,000, what is the life of the timing chain for the 22re?
      Thanks for your help above!!
         jack
Jack,  I have 340,000+ miles on my original 22r chain and guides, dual row.  Aside from changing the head the engine has never been worked on, and it still has good compression and runs well,   Nate
kyle_22r
22R and 22RE are exactly the same.  if your engine is '82 or older you have a dual row chain and steel guides that will probably never wear out :biggthumpup:
however, in '83 toyota's bean counters had them switch to plastic chain guides that break and fall into the oilpan, which allow the chain to slap around in the timing cover and wear it away.  this can case your oil and coolant to mix(not good)
i didnt mean the 22R was used up at 60,000 i meant they usually recommend changing the timing chain at 60,000,   single row,plastic guides,     300,000, is VERY common on 20R's and 22R's
