ifs front end sag
Started by bmxanddie, December 01, 2004, 07:15:32 PM
bmxanddie
Ok so i tried to crank my torsions a little to fix the sag but only one side will actually go up. I tightened them both evenly and still the right side is the only one that gives any lift. i'm thinking new torsion bars?
Fireimp141
Might as well, get downey... what i put in my truck, they are beefy.
Huhwhye
Downey bars are made by Sway a Way.  They cost a bit more too.  1mm difference.  I have the sway a way bars and I am not impressed.  They say they have good corosion resistance.  :bull crap:  The paint is coming off them and the pass side bar is rusting.  My truck is also starting to sag on the passenger side.  Maybe the bar is failing.  But it seems to be getting worse.  I paid $100 for them.   The stock ones never rusted.
Sway a Way bars = 25mm
Downey bars = 26mm
'04 Taco DC 4x4
Marketing
Sounds like the bolt striped. Very common to have to replace these.
bmxanddie
i'll check out the bolt today and see whats up
Fireimp141
I got the downey and they tuff as nails, no corrosion and they holding the lift good :thumbs:
SWAMPER
I got stock ones and they both have held the lift...no corrosion or anything...but I guess its just cause Im specialer :yupyup:
Humboldt
Downey torsion bars are really stiff and you will lose flex up front.  I had them on for about a year but then put the stock torsion bars back on.  They are good for jumping but not for crawling or street driving.  I will sell you my used Downey bars if you want.
