a\c compressor conversion to on board air
Started by jreeves85yota, February 17, 2010, 07:07:51 PM
Volcom
OK, dumb question.  I ran a 16ga wire from the AC compressor clutch wire to the pressure switch.  The other wire runs to a switch to turn the clutch on & off.  Does this switch need to be larger than a 15a or 20a?  Do I need to run a relay with this setup rather than just a switch?  I'm not sure what kind of amperage we are talking about with an AC clutch.
Thanks!
84 4Runner
Marlin Dual Ultimate crawler
Marlin high steer
TG springs
109" wheelbase
Addicted Off Road
yotatough
No u don't need a relay, you should be fine.
86rustbucket
Volcom
OK, another stupid question.  How does the AC system get it's power to power the clutch on & off?  There's only one wire coming out of it and that's the wire I hooked up to the pressure switch.  Do I need to run a wire from the battery and have the switch inline between it and the pressure switch?  I'm making this more difficult that it really is but I want to hook it up right the first time without frying wires :D
84 4Runner
Marlin high steer
TG springs
109" wheelbase
Addicted Off Road
86rustbucket
i just ran a wire from the fuse panel under the dash to a toggle switch to the pressure switch,
if you pull it from a circuit that is only hot when the key is on you dont have to worry about accidentally leaving your clutch engaged all nite and killing your battery.
you cant use it without the engine on anyway
Volcom
Quote from: 86rustbucket on April 01, 2010, 09:34:33 PM
Perfect, thanks for the help!
84 4Runner
Marlin high steer
TG springs
109" wheelbase
Addicted Off Road
86rustbucket
Quote from: Volcom on April 01, 2010, 09:58:00 PM
not a problem,   i got all my info from yotatough
i didnt know a thing about it 'till he showed me
Volcom
Do you think I need to have a bolt in this upper AC compressor bracket?
It's got 3 other bolts holding it to the block.  The bracket & the threaded hold through the timing cover & block don't line up and I've already got the compressor installed and all the lines ran.
84 4Runner
Marlin high steer
TG springs
109" wheelbase
Addicted Off Road
Volcom
Quote from: 86rustbucket on April 01, 2010, 10:30:46 PM
:beerchug: to you & yotatough
84 4Runner
Marlin high steer
TG springs
109" wheelbase
Addicted Off Road
Phazertwo
It will most likely hold, but Toyota put the bolt there for a reason.  I would take the belt off, loosen all the bolts for the bracket, and than add that bolt.  Or if that doesn't work, you can take the bracket off and drill that hole out a little bit to get even more play.
my .02
PZ
92 xtra cab, with some stuff...
Quote from: yotabj on October 30, 2006, 10:01:02 AM...why buy when you can build?
Volcom
Quote from: Phazertwo on April 05, 2010, 08:55:33 AM
That's probably what I'm going to have to do.  Not looking forward to removing everything I just installed :D
84 4Runner
Marlin high steer
TG springs
109" wheelbase
Addicted Off Road
Phazertwo
Quote from: Volcom on April 05, 2010, 09:40:38 AM
SUCK
