BAXTERS BJ BUILD
Started by baxter650, February 06, 2010, 05:34:35 PM
builttoabuse
toy obsessed!
baxter650
Nomad
My new favorite 60. Great build, subscribed!!!
Cheers!
'84BJ42; '85BJ70; '88 3BT 4Runner
baxter650
Used Front Range OffRoad's kit and installed Tundra brakes with the late231mm calipers.
So now the front brakes should more closely match the rear.
Will be selling the 15" tire/wheel combo and going to 17" stuff.
One step forward two steps back.
THATS GORGEOUS! should work much better.
baxter650
Started on the air cleaner, it will seal to the underside of the hood scoop with fire resistant foam.
Bolted to the rocker cover, hope it can handle the vibs.
Dooner
Dude :smokin: How come everything you build is soo daymn sexy
"Project Land Cruzah" In Land Cruiser Section
71 FJ40 327/465/ 4.7 Mini T/c, Trussed, Armored Mini Axles w/ High Cross Over, Aussie Lockers & 30 spline Longs.  p/s 35's, SOA, , .  86 Burb D-60 14 bolt 350/400/205 37's.  02 F350 Tow Barge, Toyo 38's, Banks 5" Wicked wheel turbo, Edge Juice w/ Attitude, Blah Blah Blah
Zs Confederate Toy
Damn that looks good. Very clean work
ZACH
87 Rock Rat X
80 SR5 The Shady Lady
Trail Junky
baxter650
Added some foam to seal off the intake from the engine and made up some inner fender filler panels from sheet plastic.
Detroit Locker for the rear.
Long slip for the front shaft.
builttoabuse
toy obsessed!
Dooner
Nice! Looks like Christmas came a little early! What ratio did you say your running in your difs? Where did you find the sheet plastic, I could use some myself.. Did you get it preformed or did you heat it up or something to get that curvature?
baxter650
I am installing 5.29s gear sets.
The plastic i get from work, as well as punch pressing and roll forming we do vacuum forming.
I heat it up with a hand held gun and formed it with my gloved hands.
baxter650
Rear third set up with Detroit.
twistedtoy92
Just read the whole build.... You my friend do some extremely nice work!!!! :beerchug:
874runnertoys
Man i'm in LOVE  :love:
SWEET RIG
Yoat Goat
Holy :pokinit:, why cant I have this guys patience??
Great work man, this has been my favorite 60 build since you started.  :thumbs:
T urning
O ver after
Y ears
O f
T rail
A buse
daniresch
Great build! Brakes and 3rd look fantastic! I recently decided to make the 15" to 17" wheel change, and am very happy I did. What wheels and tires do you have in mind?
does FRORF not sell the tundra brake kit anymore? whats it consist of and how can you adapt it to a stock mini axle?
baxter650
Quote from: daniresch on November 25, 2011, 08:08:35 PM
[/quote
Still plan on running the IROKs but in a 17" on these, bought a set of Monsters a while back.
baxter650
Quote from: THK on November 26, 2011, 01:31:18 AM
The Front Range Kit was actually for use with the Tacoma rotors. i chose to go with the Tundra rotors and upgraded calipers.
http://frontrangeoffroadfab.com/nfoscomm/catalog/product_info.php?products_id=136&osCsid=e043ee30769a50afc042f1f314a4737c
daniresch
I should have flipped back a couple pages. Love the monsters, I have the same :rockingout: but in alloy ring.
Quote from: baxter650 on November 26, 2011, 09:45:44 AM
I couldn't remember, and you follow the install as u would for taco stuff, only with tundra stuff? do you still have to mill/grind the hub body to fit the rotor hat over it? what year tundra stuff is the larger ones?
baxter650
I still lathed off the hub unit to fit the rotors i got, but you might just check the actual size of the rotors you get before machining yours.
Toyota changed Tundra caliper castings from the early 13WE @199MM to the late 13WL @231MM, from what i have read this took place in 05, i believe the rotors have remained the same.
I went with 07s because that's what wrecker near me had.
awesome to know, thanks baxter!
baxter650
The early calipers 13WE were changed to the later 13WL to solve a brake issue the early Tundra's had.
I have heard of folks using the early calipers for their upgrade with no problems, probably because they are that much larger, but i wanted the largest brakes available.
Vince B.
if im gonna go big, go big lol
baxter650
Not much of anything done to the 60 over the past few months so last week my son and i tried to make at least some progress.
Pulled the front fenders back off.
Had to install pass side inner fender and
to make it easier to replace drivers side motor mount and time the injection pump.
daniresch
my new favorite build! amazing work!
