Author Topic: 82 pickup  (Read 2005 times)
adamsbro1
  • Member since Jan '10
82 pickup
« on: Jan 26, 2010, 08:28:31 PM »
I have an 82 toyota pickup 4x4 that i have gone through 2 transmissions in the last year or so.  i have been told that this has a G-Series transmission.  first of all is this correct?????  and if so i have heard that these transmissions are pretty much junk?  i am going to rebuild and upgrade a new 22r motor for it and want to put in a new transmission as well.  what is the best option of transmission to bolt up to a 22r, or 22re haven't decided wether im going with the R or the RE but i believe the transmissions will bolt to both.
Thank you for any help with my problem.
steveco.
  • Turtle Points: 16
  • Male Posts: 321
  • Member since Sep '07
Re: 82 pickup
« Reply #1 on: Jan 26, 2010, 09:02:14 PM »
82's came with either L43 or L50 or L52's. look for a cast iron tranny. they tend to have a bad track record.  no sure about the g series. i'm sure someone will chime in.
Let's put a smile on that face!
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
Re: 82 pickup
« Reply #2 on: Jan 29, 2010, 11:05:29 AM »
the 82 came factory with a L50 trans maybe if it was a late 82 it might have had the L52  both look identical -->
the G52 is no stronger than the L series but is aluminum and will look like this -->
Re: 82 pickup
« Reply #3 on: Jan 29, 2010, 11:10:03 AM »
as far as the 22R  all of the transmissions in these early trucks will bolt to both the 20R and the 22R
the big HOT ticket is to use a early 22R block under your 20R intake and head, ive run one and its a AWESOME engine, i broke my speedo cable 3 times while running that engine over the course of 2 years when i finally dropped a valve at 7200 rpm  :down:  i cried for 3 days
Re: 82 pickup
« Reply #4 on: Jan 29, 2010, 11:13:43 AM »
if your trans is indeed a L series keep it till it wont stay in gear then get Marlin Crawlers exclusive L52HD,  it is basically a w56 gear set stuffed into a highly modified L52 housing :disturbed:  I have one myself :disturbed:
adamsbro1 [OP]
Re: 82 pickup
« Reply #5 on: Jan 29, 2010, 02:38:32 PM »
thank you it is indeed the L series.  I do have a 22r in it right now and just recently started looking into the 20r head on it and i think that is the plan.  but i want to get a strong transmission that will bolt up and when i pull my motor and tranny out i can just swap right in.  if i have to modify a little to get the best tranny i will but im not sure what the BEST transmission is.  Isn't the R150 i think? supposed to be one of the best?  will it bolt to a 22r block without an adapter?
timmaytoyota
  • Member since Oct '08
Re: 82 pickup
« Reply #6 on: Feb 08, 2010, 01:03:29 PM »
r151 will bolt up the r150 is for v6 trucks
adamsbro1 [OP]
Re: 82 pickup
« Reply #7 on: Feb 08, 2010, 03:11:58 PM »
am i correct in saying that the r151 is one of the best or would i be better off just putting the L52 Heavy Duty from Marlin in?
Last post Feb 19, 2005, 07:58:53 PM
by NUb
Last post Sep 06, 2005, 10:12:20 PM
by 81RockerToy
Last post Nov 06, 2009, 11:26:45 PM
by Sleeve of Wizzard
Last post May 02, 2006, 08:19:10 PM
by BLACKDOG
Last post Nov 07, 2007, 10:40:21 PM
by fatt_matt
