V-6 housing for a 83 mini?(better brakes)?
Started by brainlessfool, May 16, 2003, 04:02:16 PM
brainlessfool
OK so I see a lot of ppl putting V-6 rear ends in minis, so would a old (83) rear end work in a V-6 housing?? and if so are the back brakes on a v_6 housing better than the stock 83 brakes? and would a v-6 housing bolt right in to a 83? any ideas?:dunno:
#1
no problem on that swap it is a bolt on deal.  just secure your load valve to the bed and go for it!
brainlessfool
#2
good to know it will just bolt in butt, are the brakes on a newer V-6 rear end "better"?:dunno:
88runner
#3
they are bigger but better :dunno:, if you really want better brake the only way  to go is disk brake.
88 4runner v6,
5.29 with 35" tires,
Isuzu Rodeo rear disk brake,
solid axle'd
brainlessfool
#4
well my wify said"bigger IS better" so it most be!
mr4x42u
#5
yea,,however you will need spacers up front because the rear is wider..unless you like the look of wider in rear..some just upgrade to an 4cyl rear 86 and newer just to have the wider rear and then swap a v6 third into the 4cul housing...you want disks baby!! :up:
gferris5
#6
ooor..You could do a full-floater conversion at the same time and have discs, and a wider rear end and full-floating rear-end, sweet.
