ABS light
Started by 93hunter, January 08, 2010, 04:11:45 PM
93hunter
I have a 93 toyota pickup SR5 and the abs light on the dash has come on recently. From the best i can understand the abs sensor reads off the ring gear in the differential. i took the sensor out cleaned it off as well as changing the gear oil in the diff and the light is still on. i was wondering if any of you guys knew if the light stays on once a problem with the system is detected or if it should go off when the problem is fixed? is my sensor more than likely bad or is there some other problem with the system i could be missing?
93 SR5 3in body 33in all-terrains
your front hubs (what the wheel bolts to and the bearings are in) also have sensors, check those
GONZO97
not only check the sensors but check the wires connecting the sensors and what not if theres a break in one of the lines the light will stay on!
1997 4Runner Limited 3" lift on 31 M/Ts-Traded
http://board.marlincrawler.com/index.php?topic=61054.msg749103#msg749103
1995 Xtended Cab SAS on 35's Dual Cases-Sold
1991 4Runner SAS on 33s RUF 63's in the back Bilsteins all the way around, 5.29s front and rear Detroit locked Front and Rear http://board.marlincrawler.com/index.php?topic=65180.0
1988 4Runner 3.0 V6--SOLD
http://board.marlincrawler.com/index.php?topic=97592.msg1086573#msg1086573
1996 Toyota 4Runner 3.4 V6 3" OME Lift Springs 33" Duratracs
The Build:
Coming Soon
93hunter
Quote from: 79coyotefrg on January 08, 2010, 04:26:17 PM
My truck didnt come with front abs just rear abs.
Im gonna visually inspect the wires running to the sensor...theres just two of them...i wish i knew if i could test the sensor with a multimeter to tell if it was good or bad.
GONZO97
i say check the wires because on my 97 runner i pinched it on the rear axle and sure enough the pesky little light came on so just food for thought
The Build:
Coming Soon
big ron
I have a good rear sensor I could send you to try out and see if that helps. pm me your address.
