he doesnt have a lowered bump stop because mine does the same thingive thought about flipping the drag link to the top of the arm but a flat or less dropped arm
on full driver-side compression,the pitman arm rubs on the steering arm, any suggestions?
Has anyone ever run the drag-link on top of the pitman? seems like it migh :biggthumpup:t solve it.
See where they rub?
Moving the box isnt too bad and will give you the clearence you need, After i moved mine my next problem was my rod end would hit the spring when stuffed, so i put a 3/4 less drop pitman arm from skys offroad and that fixed it.
Started by cpom Parts Wanted
Started by dyogim Parts For Sale
Started by Idaho85 Parts Wanted
Started by fjclutch76 Axle/Differential/Steering
Started by Begrauger New Member Check-In!
