Optima hold down
Started by KYOTA, November 22, 2004, 05:05:28 PM
KYOTA
Replaced the battery in my 83 today with a red top Optima but discovered that the factory hold down wouldnt work. So with a little tinkering I came up with a way to use the factory bracket. In the first picture you can see that theres about 1 1/2" gap between the battery and hold down if bolted in stock location. sorry about the fuzzy pics
KYOTA
#1
So I thought if I used a spacer and a longer bolt (8mm x 1 3/4") I could just mount the hold down from underneath the core support. This was just an extra sleeve that came with some Rancho shocks.
KYOTA
Spacer on top and longer bolt thru hold down
KYOTA
#3
Bolted up thru from the bottom using the same factory welded in nut
KYOTA
#4
I also had to add about an inch of threads to the j bolt
KYOTA
All done, saved me the trouble of fabbing up a new peice. Now Im going to try and find a holdown thats in better shape that still has the rubber coating intact.
My optima came with some cheesy removable plastic dish on top that matches the normal battery height. Of course I threw mine away :thumbs:
But your setup looks stock and alot less clutter, nice :greengrin:
KYOTA
super easy and fast, not including trip to the hardware store for the bolt it took about 10 minutes
reklund5
I have a optima supplied spacer underneath the battery.  It clips onto the battery and makes it stock height.  You might check with your Optima dealer....
Ryan
KYOTA
yah  like lift blocks for batteries :gap:
Skinny_Pedal
nick used that "lift block" on his. but his tie down consist od a pice of 1/4" flatbar. he just spaced it simialr to kyota and bolted it down. very strong. was still in place after the roll
Im an OG
Dang you guys think too much.  a scrap wiece of 2x8 with short screws holding it to the battery tray from the bottom worked great for mine.  No need to do anything else.
KYOTA
Why didnt I think of that, I have some leftover wood from my truck build up too! thanks WT  :gap:
Hmm I dunno Kyota, maybe that rig could get into and out of your driveway without hitting the house......
Huhwhye
I am using the stupid plastic lift block and it still doesn't fit right.  I had to rig something up but I'm going to look at it tommorow to see it KYOTA's idea will work better.  Thanks for the tip
'04 Taco DC 4x4
