Rear axle bearings
Started by jrock, January 04, 2010, 05:40:15 PM
jrock
So I finally figured out a vibration problem that I had originally written this off as "larger than stock tires". It was actually my rear's passenger main bearing. Loose as heck and as of late has been dripping gear oil.  :slap:
Question: Should I replace the bearings on both sides? Who should I get these through? What about axle seals? I need this done very soon.  :help:
'85 axle.
junya92toy
Well if its leaking oil then yes the seals are bad. When the seals go bad, they wash the grease out of the bearings, so you need to replace them even if they feel ok. Any auto parts store should have them, try to get timken bearings.
Cheesemaker
jrock
 :blah: Yeah, I know Marlin sells all of this but I need my truck done tomorrow, Wednesday by the latest. Marlin won't get this to me in time. Plus, I don't want to dump more money into this axle when I will soon be replacing it. I just can't replace it right now, or I would be.  :dunno:
Stupid questions maybe  :_oops:
slower
i always replace both bearings and seals on anything with over 100,000 miles. if your axle seals are puking you should replace your shoes to, b/c they well be swollen with diff fluid and give you a spongy pedal. and your local Toyota dealer should have them or can get them picked up from another dealer
never once have i ever wanted to see the reduce speed ahead sign so bad
Cheesemaker
Then just go to your local parts house and get what you need.  And definitely new shoes.
Joey88RUNR
If oil is dripping down to your tire and oil flung every where your bearing needs replacement, if your shoes are oil soaked and just minor leakage onto the shoes its the inner axle seal....thats from my experience, both happend and 2 different times     :twocents:
jrock
I'm trying to be real cheap right now so what about this... I have a completly assembled passenger rear axle with drum. It looks to be in fine shape. What if I replace the seal and throw in my spare axle? Or are there other issues?
-Jake-
Quote from: jrock on January 05, 2010, 09:30:02 AM
If the bearing is in good shape then just replace the seal and throw that one in there.  I wouldn't be afraid to.
junya92toy
jrock
Done and doner. Thanks for the re-assurance.
Yoat Goat
What kind of vibrations were you getting? Mine has a vib/cavatation thing going on...
T urning
O ver after
Y ears
O f
T rail
A buse
jrock
It felt like a tire was out of balance. My truck shook at certain speeds.
bleakhorizon
lol, i have so many axles layn around here with bad bearings and good brakes... guess im just lazy...
Those are some huge welds!
Tillamook, OR
jrock
My bearings are bad and my brakes suck. :)
Cheesemaker
I see spare parts at Bleak's house!   :eyebrow:
slower
you should check u joints or something else for a vibration not wheel bearing they will just roar, unless your wheel is about to fall off
bleakhorizon
Quote from: Cheesemaker on January 06, 2010, 05:17:30 PM
yup....
well if your diff oil is leaking out onto the brakes then yea, your brakes are really gona suck..... if you still got good shoes then just spray the crap outa the brakes and drum with brake cleaner and you should be good...
Tillamook, OR
Yoat Goat
How do you check your rear wheel bearings to see if they are good or not?
T urning
O ver after
Y ears
O f
T rail
A buse
jrock
 :dunno: My drum moved up and down about 1/4 inch. When I had the axle out, I spun the bearing and it sounded rough.
Yoat Goat
Oh, seems simple. My bearings dont really have up and down movement in the housing...
T urning
O ver after
Y ears
O f
T rail
A buse
-Jake-
Quote from: Yoat Goat on January 14, 2010, 12:40:52 AM
I think one way to check it without pulling your axle would be to drop off the drum and try to wiggle the axle.
Yoat Goat
How much play is exceptable?
T urning
O ver after
Y ears
O f
T rail
A buse
-Jake-
Quote from: Yoat Goat on January 14, 2010, 04:23:42 PM
Good question I noticed when I put a new wheel bearing on one of my axles it had a little bit of play in it.  If its not screaming at you I wouldn't worry about it.  Do you think you might have a bad wheel bearing?
Yoat Goat
Well I was thinking maybe so but I dont get much play in it. I just have a bad vibration at 35 and over, my driveline has some slop in the splines, my bros d-line is much worse and doesnt get that much vibrations from it, Im just try to get arid of the vibe...
T urning
O ver after
Y ears
O f
T rail
A buse
-Jake-
is that your first gen in your avatar?
n/m  :screwy: I just saw what it said under it.  you have good taste though because thats one of my favorite 1st gens
jrock
Quote from: Yoat Goat on January 14, 2010, 05:35:57 PM
That's likely your problem. Not every truck acts the same. Yours might be getting bad vibes from less slop.
After driving for a bit I noticed my vibes are still there. Shoot.
Cheesemaker
Is your driveline in phase?
Yoat Goat
If the 1st gen in my avatar was mine I wouldnt give a damn about the vibrations!   :sly:
:highjack off: I highjacked this thread pretty bad.  :talkingn:
T urning
O ver after
Y ears
O f
T rail
A buse
