Leaf Spring Removal
Started by birfection, January 01, 2010, 06:46:19 AM
birfection
I've been working on getting my front (stock) leafs out of my 80 pickup to replace the bushings. I was able to remove the bolt at the rear of the leaf, but i can't get the 2 front bolts to come off. I've removed the 2 small captive bolts on the mounting plate, but then i can't remove the center pin. Does it need to be beat and hammered out? :_order:
TITAN CRUSHER      http://www.youtube.com/watch?v=v6qnDVgWBSA
1980 Pickup: 22RE (bored 20 over, OS Valves, 261 cam, ported and polished intake/exhaust, Pacesetter long-tube header), L52 5 Speed, 6 leaf RUF, 63" Chevies, Hi-steer, 35 x 12.5 Maxxis Creepy Crawlers, Dual 2.28 cases, Detroit Front, Welded Rear, 5.29s
ninja turtle
yes hammer that pig. they can be a pain in the butt.
this is what i had to do last time.
-Jake-
They're also flat on a couple spots so you can get a wrench on it to turn it.  I turned it with a wrench and put the nut back on and tapped and turned several times and it came right out.
84krawler
axled89
mine were pretty f#!@! up to.  like it had to be tourched out and cut off.
i love oregon wheelin.
axled89
birfection
thanks guys-took the hammer to them and they popped right out! :_order:
