Author Topic: help rebuilding front diff  (Read 3303 times)
TOY087
  • Turtle Points: -2
  • Male Posts: 135
  • Member since Jan '09
« on: Dec 22, 2009, 04:25:25 PM »
                                    :help: :help: :help: :help:
how would a i now what size shims to use on the knuckles  or does some one know were i can take it to get it done around the Los Angeles area
07 TACOMA DAILY DRIVER
87 toy 22r/lc cam/350 holley/lc headers/magnaflow,5" LIFT ,35bogger
MY BUILD:  http://board.marlincrawler.com/index.php?topic=56212.0
Re: help rebuilding front diff
« Reply #1 on: Dec 22, 2009, 06:25:25 PM »
if using the Marlin knuckle rebuild kit, use one thin and one thick shim on top and bottom of both sides
Scuba
  • Member since Nov '09
« Reply #2 on: Dec 23, 2009, 12:12:36 AM »
Yotamasters.com
Some chant and meditate, I shift into 4Low.
Rockin a 99 Single Cab Taco, Locked lifted and armored sittin on 35" MTR Kevlars.
OOPS
  • Turtle Points: 1304
  • Male Posts: 2,561
« Reply #3 on: Dec 23, 2009, 08:12:58 AM »
Yotamasters.com
X2, Jay King is a top notch Toyota tech.
Phazertwo
  • Turtle Points: 8
  • Male Posts: 812
  • Member since Aug '05
« Reply #4 on: Dec 24, 2009, 02:32:49 PM »
myyota
  • Turtle Points: -1
  • Male Posts: 120
  • Member since Nov '06
« Reply #5 on: Dec 24, 2009, 11:29:27 PM »
When the solid axle swap was done on my 86 4Runner i rebuilt the front axle, including replacing the trunion bearings. I just put the factory shims back in the same place they came from, and that worked just fine for me.
86 4Runner
Solid Axle Swap, 5'' Of Lift, 37x12.50-15 MTR Tires, 5 Speed Manual Swap, Inchworm Duel Cases With 5.7 Gears, 63'' Chevy Springs In The Rear, 5''Trail Gear Springs In Front, Marlin Crawler Third Members, 4.88 Gears With A Detroit In The Rear, High Pinion Front With 4.88 Gears and an ARB, Downey Header, Optima Battery, Trail Gear Sliders.
TOY087 [OP]
  • Turtle Points: -2
  • Male Posts: 135
« Reply #6 on: Dec 25, 2009, 02:22:03 PM »
>>>>>>>> thanks thats what im going to do i need to get truck in all 4s
TOY087 [OP]
  • Turtle Points: -2
  • Male Posts: 135
« Reply #7 on: Dec 25, 2009, 02:56:44 PM »
Last two post page 8.
http://board.marlincrawler.com/index.php?topic=24929.210
PZ
..............if i had the money  will buy the tool i wonder if autozone will have to rent it.
Last post Sep 29, 2005, 05:15:45 AM
by 1kz
Last post Dec 12, 2005, 05:31:03 PM
by kneedownnate
Last post Mar 29, 2012, 09:15:24 PM
by 79coyotefrg
Last post Apr 26, 2011, 12:46:47 PM
by Quick Draw
Last post May 15, 2017, 05:54:54 PM
by Hickory Nut
