...why buy when you can build?
I actually worked on my truck!I also got the cases out, to fix my nasty leak.Inch worm has changed the design of there V-6 adapter since I bought it a few years back. I called them and they upgraded mine for $45. Here is the adapter, with its new insert.+=Pic is kinda confusing, but it will make more sense when I take a pic of it installed!Also, here is my cross member that I bent up real quick. If you look hard at the t-cases you can see the tube it mounts to on the back.Hopefully I can get some of this slammed back together tomorrow, and start work on my front axle, and my new carrier bearing mount!PZ
So much for getting it slammed together. seems my tranny is leaking out of the intermediate plate. Guess i get to learn more about this tranny than I want too.....
what gasket sealant did you use when you put your cases back together? Paper gaskets or store bought sealant?
My tranny is also leaking there. Havent tore it apart yet. Post some pics of how that goes so i know what im getting into
love the pics of the trany!! thanks...gonna help out ALOT!!
the tube through the rear of your frame that is capped off...... pull a plug and its a magic little birf buster
Great build up! Just read though from start to finish
Nice Build!
Started by Rock_Starr General 4WD Discussion
Started by yotadork83 « 1 2 ... 6 7 » Project Research and Build-Ups
Started by supratruck Parts For Sale
Started by BadnewsBob Project Research and Build-Ups
Started by 83Camo Newbie Questions
