are you sure? the spacer takes the place of the crush sleave... you dont remove the shims from infront of the pinion bearing....
yeah but you have to get the pinion pre-load set right which requires spinning which won't happen with the 3rd in place. The way you adjust it on a solid spacer is with shims.
yea i got all that, what theay are talkin about is settin pinion depth, installing a solid spacer will not change PD, you still have to remove the 3rd to set the pre-load, but if the gear set was set up right before the depth wont change if you just swap the in the spacer
This is my DD, so it'll probably be awhile. Thanks
Started by 1Bad4Runner General 4WD Discussion
Started by RN37DD Engine
Started by muddenyota Toyota Pickup/4Runner Tech 1979-95
Started by Dr Phat Parts For Sale
Started by beefyjw Axle/Differential/Steering
