0 Members and 8 Guests are viewing this topic.
You might need someone to bang on the starter while you try cranking it over.. Its pretty common, well that ive experienced, not sure if thats your problem, might be worth a try.
If it is that a new starter will cure it.
I'd strongly suggest not just replacing the starter, even if it's the problem. If he's lucky enough to have a denso starter, it's cheap and easy to fix, and you don't end up with some craptastic replacement or rebuild. It's not uncommon for the plungers to get gummed up and stick, the ring on the plunger to get too thin or beat down, or most commonly the contacts, all of which are an easy fix and the parts are available from toyota.
Started by 90slvpup General 4WD Discussion
Started by offroadin88 Toyota Pickup/4Runner Tech 1979-95
Started by REG535 « 1 2 » Toyota Pickup/4Runner Tech 1979-95
Started by spaded1 Toyota Pickup/4Runner Tech 1979-95
Started by jji Toyota Pickup/4Runner Tech 1979-95
