Trans Case Flange Bearing?
Started by Yoat Goat, November 25, 2009, 03:50:40 PM
Yoat Goat
My t-case has some play in the rear output flange, thinking it might be the reason for my vibration. Now my question is if I take off the smallest cover on the rear trans case, will that be enough to get at the bearing. Thanks guys!
T urning
O ver after
Y ears
O f
T rail
A buse
Yoat Goat
T urning
O ver after
Y ears
O f
T rail
A buse
boggerunner
yep, pull the flange and the 7 bolt cover, and the bearing will pull right off by hand.
zippo
Is the play in/out, left/right, up/down. or rotational looseness? That rear bearing alone would have to be just smashed to cause that. your T-case might just need a good ol rebuild.
If you see it, its for sale.
