That's exactly what it looks like, only difference is its candy apple red and white. I actually got it running tonight. Just changed the oil and the gas and it fired up. Then I adjusted the valves. It needs a new spark plug and a carb rebuild, and the air filter is missing and that's it. It runs pretty good considering. And the tubes are holding air. Tires are really cracked though. It didn't come with a key so I had to "hot wire it". The lights don't work, but thats because its connected to the key switch.
I figure after I fix everything I'll be into it for $50 total.
