help engine code
Started by traveler727, November 13, 2004, 03:16:03 PM
traveler727
Hope everyone having a good weekend. My 86 4runner is flashing a code (22re) first it flashes 7 times then 11 times I have an fsm but let a friend borrow it so I can't look it up myself. Thanks for the help everyone
BLUCRUZ
7 is a throttle position sensor signal, open or short in the sensor connection
11 is switch signal, short circuit in terminal "t" when IDL point off, once again it refers to the TPS.
Good luck.
72 FJ40. 350 Multiport EFI, turbo 400, ORION T-case, 35 Procomp's  disk brakes front & rear, ARB's F&R and an onboard shower for the ladies!
86 sr-5 4runner SAS conversion. E-lockers F&R, 5.29's 4.7 Marlin case.
PurpleYotaGirl
traveler727
Found the problem the connector to the tps was loose
thanks
