what do you think???
Started by kiefer1980yota, November 11, 2009, 08:07:29 PM
kiefer1980yota
1) I jus swapped a 22r out of a 1983 into my baby that is a 1980. When i did the swap afew people that i talked to told me i have to wire the 20r altanader for some reason. I listened to them and did it and now my batts not keepin a charge. Was i wrong to listen to them? I think i am but am unsure.
2) Because of the swap ive got a good 20r head and have been told i can get more power out the truck by swappin the heads but is it enough to really mater and make it worth my time and work?
1980 toyota 4x4 swapped in 22r and 5speed
Triumphant
Over
Years
Of
Terrible
Abuse
it (20R head on 22R block) does make a good bit more power, but if your engine is running fine just hang on to the 20R head for later on down the road when maybe you blow a headgasket
and you should have kept the alternator that matched the 80 truck wiring
kiefer1980yota
so i should have the 20r alternator on the 22r engine?
Triumphant
Over
Years
Of
Terrible
Abuse
NorCalToy
Quote from: 79coyotefrg on November 11, 2009, 08:17:37 PM
:flipoff: i wasnt wrong!
and about the head swap...I wouldnt swap it til you need to like Glen said
:flamer: IFS
83yota
just wire in the GM 1 wire alternator. that will fox your problem
kiefer1980yota
thats a good idea and in time im sure i will but for now i just wont to get it on the road and see it movin again
Triumphant
Over
Years
Of
Terrible
Abuse
