Author Topic: Rubber stop/pad for dual shackle set up?  (Read 1760 times)
studentwheeler
  • Turtle Points: 121
  • Male Posts: 382
  • Member since Feb '06
« on: Nov 10, 2009, 09:23:32 PM »
Hey guys need some help: Just in the middle of installing chevy 63's on my junk with a dual shackle set up. What is the best thing to use to soften the blow between the top shackle and frame once the suspension comes back up?
Cheesemaker
  • Turtle Points: 1346
  • Male Posts: 4,525
  • Member since Sep '04
Re: Rubber stop/pad for dual shackle set up?
« Reply #1 on: Nov 11, 2009, 09:14:08 PM »
Most people abandon the idea and just go for regular shackles.  Either or they just live with the slap of steel on steel.
86bobbedtoy
  • Turtle Points: 686
  • Male Posts: 3,938
  • Member since Oct '06
« Reply #2 on: Nov 11, 2009, 09:53:46 PM »
I have seen IFS front bump stops cut down and used
86bobbedtoy
  • Male Posts: 3,938
NorCalToy
  • Official Super Badass
  • Turtle Points: 77
  • Male Posts: 2,472
  • Member since Jun '07
  • IFS no longer! - Member #8342
« Reply #4 on: Nov 11, 2009, 09:58:47 PM »
x2
the little round IFS bumpstops should work well and its as simple as drill a hole (3/8"?) thru the frame and tighten the nut on the backside
photo courtesy of 46&2
:flamer: IFS
Jud
  • Scumbaggin
  • Turtle Points: -261
  • Male Posts: 3,067
  • Member since Oct '05
  • Gettin it since 1990
« Reply #5 on: Nov 11, 2009, 10:04:40 PM »
I ran some bumps off a ifs Chevy 1500 under mine and within one trail run the bump tore in half. I've run metal on metal for over a year and a half and it hardley ever "slaps". Only when you hit a jump or are fully dropped out and the tires are like spinning/hopping.
"bout tree fiddy"
studentwheeler [OP]
  • Male Posts: 382
« Reply #6 on: Nov 11, 2009, 11:04:32 PM »
Alright thanks guys. I'm not sure about the whole dual shackle set up anyways so I'll just run metal on metal for a bit and then decide whether to go new spring hangers or do the ifs bump stop, that looks like the way to go.
Last post Jan 20, 2006, 08:08:12 PM
by kneedownnate
Last post Jan 10, 2007, 07:11:56 PM
by Shamb
Last post Jun 19, 2007, 01:51:55 AM
by Snowtoy
dual shackle
Last post Mar 24, 2012, 07:50:01 PM
by 79coyotefrg
Last post Nov 27, 2020, 06:21:31 AM
by trigrate
