84 ex cab 1tons duals 4.7s and 42s finishing touches.
Started by 89sastoyo, October 27, 2009, 06:19:10 PM
89sastoyo
Hey I'm building an 84 extra cab on 1 tons.
The truck has
king pin 60 front
14 bolt rear welded
duals rear case has 4.7s
ranger rears fliped around in the rear johnny joints
toy rears mixed up front
flat bellied
custom tranny tunnel
22re swap
cold air intake
hids
clean bob and dovetail
And some other stuff
Ok so for the parts im putting on it.
just finished the rear disc swap on the 14 bolt.
weld ons just got here yesterday.
double sheer high steer is on its way
Still need to order 42s
Things still left to fab
bump stops
bumpers
sliders
cage
finish gusseting the full width hanger
flat belly skid
fuel cell
I will post some pictures up this weekend.
89 extra cab stock on 1 tons.
92 2wd DD
first gen cab
Check out the build.
89sastoyo
in the drive way on its way to the shop
Flex test after the perches were welded and everything was tightend down
In the shop..check out the clean bob and dove tail I narrowed the tail gate to just no pictures yet
92 2wd DD
first gen cab
bigarms23
looks good with those small tires on the back it looks like the pumpkin is on the ground
89sastoyo
Quote from: bigarms23 on October 27, 2009, 09:40:47 PM
HAHA it basically is but it crawls amazing on rollers no joke with the 4.7s and 4.56s it just goes anywhere I crawled the little rock garden at my house its going to be bad when its got 42s for sure.
The plan is getting everything done and solid before the tires are ordered that way when there here it can go to the trail.
92 2wd DD
first gen cab
89sastoyo
top view of the dove tail and the ghetto mount fuel tank ha.
bob
Rear axle
homebrew shock mounts
disc conversion
homebrew front shock mounts
60 to toy adaptor
The spring hanger was originally goign to be ressesed up that high but plans changed so that needs to be gusseted and cleaned up
Flat belly
cab mounted battery I have the tray its just not mounted right now
front approach will be rediculous with 42s
92 2wd DD
first gen cab
thegoofster21
Quote from: crawlerdad on October 08, 2009, 08:21:17 PM
Any guy who takes his woman wheeling enjoys her. A woman who is owned is left at home to cook, clean, and keep beer cold. So if this offends you you should stop looking and go have some tacos.    :rofl2: And a beer. If your old enough.   :beerchug:   :beer:
04 Tacoma 33s http://board.marlincrawler.com/index.php?topic=61454.0
jmoffroad.com
89sastoyo
for sure its my buddies but its at my house and were pretty much building it and mine for test dummys haha. ten minutes from my house is goat mountain which is a pretty good wheelin spot but there is some tight trails so we'll see how it does. At browns it will do awesome though. He had a 1st gen that we stripped to the frame ended up not being worth the work due to lack of time from working so he picked this up for a project. He took automotive threw high school and I took manufacturing and engineering so I'm doing all the fabbing according to what he wants and he does all the motor axle and that sort of work.
He's 20 and I just turned 18 so we should both have pretty good rigs for our age.
92 2wd DD
first gen cab
thegoofster21
yeah that is good for your age for sure. when i was 18 i had a off road only toyota on 40s full cage built everything and a ford tow rig. i miss them days. you guys look like you know what your doing so keep up the good work. :beer: for me and soda for you guys sence your to young haha
jmoffroad.com
89sastoyo
Quote from: thegoofster21 on October 29, 2009, 07:39:11 AM
for sure I don't drink anymore.. it got me in trouble so....
But thanks thats pretty much where im at once I get the tow rig back together needs the water pump put back in it and my trailer its going to be re-decked and painted and ill be set.
92 2wd DD
first gen cab
thegoofster21
jmoffroad.com
89sastoyo
pristine 93 ford f350 it has a 460 in it but its only got 110 thousand miles and its really clean my dad has owned if for like atleast 12 years I would say he got his diesel like 6 years ago and stopped driving the 93 3 years ago so its just been sitting I need to put the water pump and radiator back in it and it will be rollin.
92 2wd DD
first gen cab
thegoofster21
you cant go wrong with a 460. my dad had an 87 2wd with a 460 ever good truck
jmoffroad.com
86bobbedtoy
Im diggin this build.
looks awesome
"approach on 40s"- there wont be an approach your tires will hit first, lol
should wheel sweet
89sastoyo
Quote from: 86bobbedtoy on November 02, 2009, 09:47:16 PM
looks awesome
should wheel sweet
Thanks man it will be getting work done shortly its pretty much all little odds and ends left that I haven't taken many pictures of but all the big stuff ill document. I just can't wait for it to be wheelin.
92 2wd DD
first gen cab
Miguel
89sastoyo
92 2wd DD
first gen cab
xxiong12
89sastoyo
thanks.
Ok so finally got some work done. capped the end of the spring hanger off to get rid of the gap here is a pic the other ones sucked to bad cause I took them with my cell. Let me know what ya think.
Also got the exaust done just 2 3/4" to a flowmaster actually sounds good for a flowmaster haha I usually don't like the sound of them just because everyone runs one.
mixed the front springs because they were de-arching. Due to mixing them and gaining arch they gave it a horrible shackle angle so me and max were debating about putting rears up front and losing the approach or letting these settle and or maybe moving the shackle mount. They still flex good there just isn't enough shackle movement.
Also max ground down the remains of the old sliders and got that all prepped. Ballistic ships pretty slow but the double sheer highsteer is on its way and then the front will be dialed minus bumps. The rear needs the 14bolt to toy adaptor which will probably be on order by the end of this week then taking the driveline into Driveline tech when that arrives. This week max is going to try and get some custom break lines made for the rear instead of running an adaptor from hardline to the banjo fitting for the rear disc he's going to have one line made for it. once thats done it will have breaks and then the running gear is done. After he gets the tires ill make the bump stops and it should be wheelin. The new plan I think is just get it done as much as possible like just legit enough to drive and wheel then buy as needed instead of going all out at the beggining because he wants to wheel.
92 2wd DD
first gen cab
89sastoyo
oh and I got the weld ons all welded up and ground smooth me and halladay came up of a really good bead lock color so be prepared for it.. max is doing his and ill be doing mine as well but max's will be done first since there already off and need paint as it is.
92 2wd DD
first gen cab
89sastoyo
So we got a lot done since the last time I posted. We have gotten the rear drive line done it was made by brian at driveline tech, its toyota to a 1350 u joint and instead of straps its the u bolt style pinion flange made for the 1350. We put the ballistic steering on I made the tie rod and drag link. since the guy before wasn't running the springs under it now he didnt move the ifs box forwards enough so Im going to have to move it forwards as much as I can but it rolls around now just makes contact if its flexed out at all. Also got the 42s on the bead locks and mounted on the truck today it looks really good. Heres some pictures.
90 degree aproach we put a piece of plate in front of it it makes contact with the tires and the hanger at the same time with the plate plum.
and heres the ballistic double sheer arms and the interference.
92 2wd DD
first gen cab
89sastoyo
all thats left now is mount the rci fuel cell, buy fittings for it and hook it up, move ifs box, bend rear break line, blead the brakes, measure for bump stops, top all the oil off, fix one exaust leak, maybe a couple more random things but its pretty much done. Im gonna go order the bump stops tomorrow and get a banjo bolt for the rear disc should get the breaks done tomorrow. I dont wanna move the box untill max is at the shop so he can call the shots I just do the welding and dont wanna do something he doesnt like. Should be done by next weekend maybe a test run if it snows at all.
92 2wd DD
first gen cab
thegoofster21
that truck looks good on the 42s
jmoffroad.com
83 Crawler
looks way sick! alot better then the last time i saw it!
SocalWheeler71
That thing is a monster on those 42s! Nice build, check out my build in my sig, we did the exact same thing to the front hanger, at least you didn't finish yours. I tried running mine that way for a year and it was nothing but trouble.
86bobbedtoy
89sastoyo
thanks a lot guys and yeah that hanger idea woulda have been troubles It seems like a good idea but I just didnt see it working out.
Also It sits tall in the front but im going to re-drill and move the shackle tubes forwards for a better shackle angle since the main leaf on these are really short but give it a great approach angle.
He wants to lower it a lot so we'll see what it looks like pretty soon.
92 2wd DD
first gen cab
89sastoyo
92 2wd DD
first gen cab
89sastoyo
ok so I do have a question or 2 I want to move the rear axle back what do ya'll think? just a few inches it looks to crammed forwards to me just because theres more room behind it than in front just seems like it would be more proportional and wouldn't sufferr to bad but I dont know lol. Also would like comments on the sliders? I just like the way they look anyone ever ran them like that tucked up high and away? ran a cage off them anything. I like opinions thats why its on here but people only say good job lol.
92 2wd DD
first gen cab
crawln503
what gears are in those axles, and did you upgrade the Brake MC?
and mad props on the rig :beer:
-85 ext cab swap on std Toyota frame, 3rz, built narrowed 6 lug 60's duals/4.7 42's iroks
-94 Ford CCLB 12v. 6spd, pump cranked, guages, lifted & lots of other mods:smokin:
-89 ext cab Toyota, 3.4, 5spd on 33's
