ahhhh more motor probs
Started by DontStall Rockcrwl, November 08, 2004, 04:54:36 PM
DontStall Rockcrwl
about a month ago i was having some starting problems so i got a new cap and wires. that seemed to fix it until i let my truck sit for a while. now the motor turns over but doesnt start at all. there is gas going to it and i havent checked for a spark yet. i tried bumpstarting it and it will not start. the battery has juice becuase all the stero and light componets work fine. anyone got any tips on what to check next?
You have all gotta be jealous how close i live to the 'Con
SWAMPER
 :_order: hammer the starter, clean your battery post, check the grounds and wires :beerchug:
is the motor spinning and not starting or does it just do nothing, in which case you need a starter,   go with the gear reduction starter
brainlessfool
OK, time for some "shade tree" exprtease! here's what to do, just put the coil wire end in your hand and grab the fender. then have some one crank the truck! if your eyes light up you've got spark, if not chack ing.
   now mike will come along and tell ya not to do that!  :smack:
butt ya got to see if you have spark, NOW!   :psss:  :beerchug:
Mike D
even butter stick your tounge in the hole on the front of the coil and then crank her over.
DontStall Rockcrwl
yeah the motor turns over, i could use the starter to move it which i had to do today. im gonna check for spark tomorrow... and not the shade tree way
brainlessfool
It's more fun the shade tree way! not for you, butt for those watching!  :yupyup:
:rofl:
brainless,  PLEASE change your avitar
brainlessfool
here, something like this
DontStall Rockcrwl
yeah, checked, there is no spark. there are these little things in the distributor, the contact points, that can be replaced i was told. just some phillips screws. gonna replace those tomorrow and see what happens  :crossed:
Mike D
Yes they are replaceable but it is not mechancial pionts it is an air gap style piont that is not adjustable and expensive. if you are getting no spark at all then check out your coil and igniter
yotaboy79
im with mike, i had the same problem, it was the coil and igniter
brainlessfool
Mike D
judgeing from his avitar im going to guess 84
DontStall Rockcrwl
yeah it is an 84. igniters can cost quite a bit also though. i have an extra one sitting at my house, i took mine out ant tested it on a buddies truck and it worked fine. started the truck right up.
DontStall Rockcrwl
yup, i tested the coil wire for spark today, after replacing the ignitor and there was spark. but still no start. so i put some gas in the carb and after about 20 cranks it started up. hopefully problem solved. thanks guys
Hmmm,  :headscratch: you have a stock carb dont you
DontStall Rockcrwl
sounds like maybe a fuel cut solenoid trying to go bad
DontStall Rockcrwl
yeah its definatley narrowed down to a fuel delivery problem. gonna check out the lines, filter etc.... on sunday, and i will give u guys an update
ok  from the pass side look at the carb,  right at the top on the pass side is a small solenoid with a wire coming out of it,   get you a piece of wire and run to a key on source , and attach to the plug ,  going to the solenoid,
$20  says it fixes it
befor my webber if my truck sat more than 12 hours i had to prime it :smack:
