front top shift case pops out of gear
Started by timmaytoyota, October 20, 2009, 06:18:20 AM
timmaytoyota
 :headscratch: i have a first gen 83 pick up, i ended putting duel cases in wih a g52 trans. and top shift case that was on the trans and my original top shift 83 case in back. the problem i have been having is that the top shift case or front case pops out of double low, only when going down hill. i have tried putting in the heavy duty detent spring into the front case. it made the shifter feel alot tighter but it still pops out. what else should i try. and would one of marlins heavy duty shifter bushing for the top shift help this ???  :hammer:
axled89
that might help.  i would give them a call at marlin.  i have never herd of this happening. :beer: but i'm no expert.  i rebuilt my dauls and every thing came out fine so i don't know. :beer:
i love oregon wheelin.
Halladay
you didnt cut you shift rail as short as it needs to be.. i had the same problem... you have to pull your cases apart and grind it down a little more and it wont happen anymore..
axled89
there you go there your answer.   i was allways thinking why they make you cut that.
axled89
timmaytoyota
thanks for the quick response  :clap: guys i was hoping i wouldn't have to pull the cases apart :hammerhead: but oh well.  i'll try and get that done this weekend and report back to you guys  :crossed:
Halladay
Quote from: timmaytoyota on October 20, 2009, 11:35:44 AM
cool lets me know... you can grab your shifter and put it in low range (when the cases are apart) and then you have a little more play in it push the shifter to were it will not move anymore and grind it flush with the case... make sure you dont grind the case though or there will be a chance of it leaking... good luck and post some pics!!!
timmaytoyota
i just noticed in my first post i put that have 2 top shift cases  :smack: actually my front case is a forward shift and the rear case is top shift :outtahere: does this change anything :crossed:
Halladay
Quote from: timmaytoyota on October 21, 2009, 08:15:25 AM
not positve on that but i think it will not change anything... ill send this leak to buddy with your same set up.. i have two top shifts...
89sastoyo
It actually does affect it more so then two top shifts for some reason the rails have a higher chance to hit. I may be wrong but all top shifts I have done work with a little bumping but mine I had to cut about a half inch off. If you looked at the picture Halladay posted it shows where and which rails he cut. You odviously dont have to cut the rail going into the adaptor because it goes to no where. You need to cut the rail that sticks out of the crawl box going into the adaptor because it hits the 4wd rail on the rear case. I may have just said taht wrong but thats the on you'll want to cut. Just be carefull not to cut it past the marks for the detent ball, I left about a quarter or more of an inch after before the cut. I think I also cut the other rails  so they didnt stick out of the case at all when shifted it just seemed like a good idea lol.
89 extra cab stock on 1 tons.
92 2wd DD
first gen cab
Check out the build.
89sastoyo
Bahah i didnt like how I worded that. For simple folk talk the crawl box shift rail hits one of the rails on the rear case which allows it to pop out or not want to go into a gear. You can avoid this by shifting in a certain pattern but they tend to want to pop out. If you just cut which ever shifter sticks out furtherst or both then it will keep them from hitting and should solve the problem. If not I have no clue why it would do it but I would check if the shift for and all the junk is in correct order because mines flatt bellied and makes horrific sounds like it wants to pop out but never does.
92 2wd DD
first gen cab
timmaytoyota
thanks for the input guys i actually might be buying a top shift case from a guy on the boards
timmaytoyota
i finally installed marlin hd bushing tor t-case   :clap: works alot better took on a ttrip last weekend did awsome :driving:
um, you said G52 to top shift and top shift :headscratch:
G52 should have a forward shift tcase behind it,  unless you blocked off the rear shift hole on the G52
G52 to forward shift crawl box, then a topshift case in the rear
timmaytoyota
YAH i notced that a cupple days after i posted, and then i mentioned that a couple of post up :disturbed:
timmaytoyota
the heavy duty bushing helped out for a little while but not anymore
so me and a buddy finally pulled the cases apart to install my 4.7 gears i got with my income tax return. well there was a bearing in the back of the case that fell apart in pieces  :yikes: . oh well i just had o go home and get some spare parts from when we put the dual cases in. the next day we get started finish the 4.7's then get started on top shift conversion on the front case, and to are surprise the pilot bearing that goes on the input for the abdapter wasn't there  :smack:  :_oops2:. so i go back to my house to look the spare parts there it is. time to put back together now.
so i have been driving it around for 2 weeks or so trying to finish the break in period on the 5.29's we did the weekend before.  haven't gone wheeling yet to try it out yet :soapbox: :rant:
someone asked for pictures awhile ago so here are a few
http://s995.photobucket.com/home/timmaytoyota
timmaytoyota
my photo bucket will only put links instead of pictures i don't knowe what the deal is :maddest:
86rustbucket
you gotta click where it says insert image on top of  ;)  this smily
and paste your link between  img] [img   <----   these things
timmaytoyota
ok i finally figured out tmy photobucket so here are some pics
