purple power first then pressure washer youl be able to lick it when your done
parts washers are good 4 everything but the housing
I plan on knocking the seals out of it and blast it real good with brake cleaner until the fluid running out is clear. I've done too much to it to risk it rusting from the inside out.
If it's thick and built up you'll have to scrape and scrub anyway, especially if it's old and baked on. I've used a steam cleaner and super clean and still had to scrape crap off.
is'nt that a carpet cleaner??
Ive heard oven degreaser works well.
oven cleaner does do pretty well
I run simple green in my parts washer. You can buy it by the gallon at ace hardware for cheap. It works well and it is also easy on the hands.
Started by BigMike « 1 2 » Parts Wanted
Started by madmax21tm Parts For Sale
Started by LAGEN WAGON « 1 2 » Parts For Sale
Started by Redbeard1 Parts Wanted
Started by emsvitil Chit Chat Camp
