Author Topic: "Old Red" 84 build --> Dual cases and Lift in progress  (Read 10040 times)
Yota-Freak
  • Male Posts: 469
  • Member since Jul '08
  • Pass tha' whiskey and that rot gut Shine.
gotta convert bro, sorry
Dark Knight [OP]
  • Turtle Points: -4
  • Male Posts: 133
  • Member since Sep '09
  • 88 SR5
any other thoughts on that? I believe it can be done, forward shift on the g52 and top shift t-case as the rear case of the dual's
I hope...
89sastoyo
  • Turtle Points: 148
  • Member since Jan '09
you dont have to convert anything.
if you leave the t case you have in your truck right as the crawl box then you can utilize the forward shift. If you are scared the new case might leak then you would have to buy a conversion kit to do so, or swap around the shift rails from case to case. You only need a top shift in the rear case because you will have no where for the forward shift shifter, or shift rail for that matter, to go.
If that doesnt make sense let me know.
As for all of your other questions which weren't really answered,
you want to push your front axle as far forwards as you can if not you'll regret it down the road. I would use the trail gear hanger I have it on mine its super low pro and actually moves the axle forwards the most if you mount it right. Its also not a big drop hanger. When installing it you should move it forwards from sitting flush on the frame. Halladay said look at his, I did his solid axle swap we moved the skys hanger like a 1/4 forwards maybe more like 1/2 not sure off the top of my head but with that and his mixed pack of rears his axles about 3 or more inches forwards.
When you do the rears I would use boomerang shackles because they are meant for a steep shackle angle without making contact with your body mount so no notching required.
When you do the rears and everything then you must use high steer and an Ifs box as well.
89 extra cab stock on 1 tons.
92 2wd DD
first gen cab
Check out the build.
Dark Knight [OP]
  • Turtle Points: -4
  • Male Posts: 133
  • 88 SR5
Thanks for the explanation. Below is the top shift reduction case I have. The idler bearings dont turn, also missing shifter base.... I am going to scrounge up another 100 bucks and go pick up a t-case in my area soon...
Dark Knight [OP]
  • Turtle Points: -4
  • Male Posts: 133
  • 88 SR5
Found a highsteer kit and ifs box from an 88 4runner for $300 bucks. :woot: I'm going to pick it up next friday, the guy says it is a Marlin highsteer that is about a year old. I have not seen one in person before, is the any definitive markings on the knuckle arms or rods that will stand out and let me know its "Marlin" for sure?
CrazyYota
  • Turtle Points: 92
  • Male Posts: 1,073
  • Member since Oct '05
It should say Marlin Crawler on the arms.  :biggthumpup:
Dark Knight [OP]
  • Turtle Points: -4
  • Male Posts: 133
  • 88 SR5
Did I read somewhere where there was a redesign on the arms at some point??? I could be imagining that or thinking of Allpro maybe??? If there was a redesign will both versions have MC stamped on them?
Dark Knight [OP]
  • Turtle Points: -4
  • Male Posts: 133
  • 88 SR5
Getting close to being able to build. I have most of the big parts except 5.29's and Aussie lockers and tires/wheels. Lots of small nicknacks and mounting hardware yet to buy. ohh and a clutch.
Dark Knight [OP]
  • Turtle Points: -4
  • Male Posts: 133
  • 88 SR5
Anyone need any Top-Shift parts? Idler bearing has been cleaned up a bit and turn pretty well.
Mavericks
  • Turtle Points: 2535
  • Male Posts: 256
  • Member since Apr '08
I'll be watching this build, you got a nice platform to start with! Your getting a nice collection of parts too.
1985 toyota SR5, 22re,  5.29's locked front and rear, duals with twin stick, longfields.
axled89
  • Turtle Points: 296
  • Male Posts: 2,526
are you going to be hangin new sheet metal??
i love oregon wheelin.
Dark Knight [OP]
  • Turtle Points: -4
  • Male Posts: 133
  • 88 SR5
Nope, no new sheet metal on the front. I will be trimming the fenders to fit 35's (I hope) so the rust on the front will be cut out.
greg_k113
  • Turtle Points: -49
  • Male Posts: 224
  • Member since Feb '10
Nice build keep the pics coming.  I love the Ruff chevy combo.Something about a great suspension set up that you can get for under $100 is so cool.
Last post May 18, 2006, 11:06:44 PM
by scyota
Last post Jul 26, 2006, 06:04:53 PM
by Broke_Okie_Ty
Last post Oct 05, 2011, 04:02:49 PM
by Shamb
Last post Jul 17, 2008, 05:25:15 AM
by 79-83earlyota
Last post Mar 02, 2023, 11:21:58 PM
by dms3
