More Power To ALL Yota Drivers. H$LL Y$AH!!!!!!!!!!!!!!!!!!!!!!!
Started by Runninthetrails, November 01, 2004, 09:40:03 PM
Runninthetrails
 :bowdown: :driving:
I Love my Yota but, I just keep having problems after problems with it.  Oh, did I mention I am having problems with it.  I have NO Electrical at all, and it doesn't run very well.  It keeps bogging out and when I want to stop I have to keep giving it gas while i'm braking or it will die on me.  My dash lights stay on all the time until I turn my headlights on, then they want to go off.  Does anyone have any suggestions of how to fix some or all of the problems.  PLEASE I would love to hear them.  Just send me an E-mail, I would love to hear from anyone with some suggestions.  I want to drive it and take it wheelin so bad!!!  Thanks a Bunch.
Wow :ack:
Gotta start on one at a time :yupyup:
oh, and :welcome: :wave:
About the stalling problem when coming to a stop, check for a vacum leak, specifically near the brake booster, and also remove your fuel filter and try to blow through it, chances are its a bit plugged up. A new fuel filter will allow enough air to pass through it as you exhale normally. So basically zero pressure is required. If you cant simply exhale normally through your fuel filter, it wouldnt hurt to replace it.
About your electric woes, it sounds like you've got a real lemon on your hands :banana: Might want to start looking around for bad ground wires. Take a multimeter and check ever wire that is either "Brown" or is "White with a black stripe". These are common Toyota ground wires.
Before I can really dig into more about your engine dieing issue, I need to know if its EFI or Carb?
Thanks and welcome again :beer:
