Author Topic: Grip shift idle adjuster build  (Read 4163 times)
Steve_925
  • Turtle Points: -86
  • Male Posts: 1,876
  • Member since Feb '07
  • F***in catalina wine mixer
« on: Sep 01, 2009, 06:44:51 PM »
just got done making it. was pretty easy and ended up only costing like $15
started with my inch worm shift knobs. i was hoping to be able to use the tranny shift knob it was way too big.
started by cutting the knob down with a sawzall. then i ground it all down to 7/8"
you can see in the pics that the lower part of the knob was already 7/8".
once that was done i took the piece off the throttle body that the foot pedal goes to. for some reason there are two of the throttle cable guides. one was in reverse direction so i cut it off and welded the two together. then drilled a hole next to the pedal cable for the grip shift cable to go through. ran the cable and housing through the fire wall. that's about it was pretty easy.
oh ya almost forgot the only bad part is the cabl pulls alot. i was hopeing it would be less. its a 7 speed shifter and on the 7th click its at full throttle. on the first click with it in neutral
the rpm's are way hi. hoping it works out once its in gear and under load
EDIT: just fixed the problem. there an adjuster on the shifter so i was able to fine tune the first click
« Last Edit: Sep 01, 2009, 07:06:13 PM by steve_925 »
UA 342
STEAMFITTERS
jrock
  • Turtle Points: 77
  • Male Posts: 3,395
  • Member since Oct '06
  • Oodelally
Re: Grip shift idle adjuster build
« Reply #1 on: Sep 01, 2009, 06:47:08 PM »
Nice work.
Does that allen screw hold it on the old shift knob?
Jud
  • Scumbaggin
  • Turtle Points: -261
  • Male Posts: 3,067
  • Member since Oct '05
  • Gettin it since 1990
« Reply #2 on: Sep 01, 2009, 06:48:50 PM »
That looks sik!
"bout tree fiddy"
Steve_925 [OP]
  • Male Posts: 1,876
« Reply #3 on: Sep 01, 2009, 06:53:37 PM »
That looks sik!
your shifter is way cooler.
UA 342
STEAMFITTERS
axled89
  • Turtle Points: 296
  • Male Posts: 2,526
  • Member since Jan '09
« Reply #4 on: Sep 01, 2009, 07:03:57 PM »
looks good bro.      i will have to buy your next one ha ha.      :beer:
i love oregon wheelin.
BUDDERS
  • Turtle Points: 15
  • Male Posts: 1,335
  • Member since Jul '05
« Reply #5 on: Sep 01, 2009, 07:15:45 PM »
Now that's exactly what I had in mind!  Good work!
locked 4x4
  • Male Posts: 466
  • Member since Aug '09
« Reply #6 on: Sep 01, 2009, 11:57:16 PM »
have you had any problems with that affecting your foot peddle throttle cable
Steve_925 [OP]
  • Male Posts: 1,876
« Reply #7 on: Sep 02, 2009, 12:20:23 AM »
ill let you know as soon as i accually use it
UA 342
STEAMFITTERS
82juguete
  • Turtle Points: 5
  • Member since Jan '07
« Reply #8 on: Sep 02, 2009, 12:27:45 AM »
I had a little problem with the idle running high when i would stop with my traditional style hand throttle.... it seemed like it would just get hung up on the last 1/4'' of return.  I put a stiffer throttle return spring, problem solved. Just something to consider if you have a similar prob.
Steve_925 [OP]
  • Male Posts: 1,876
« Reply #9 on: Sep 02, 2009, 02:01:17 AM »
since i made my own gas pedal a had to put a pretty strong return spring on it. so hopfully im set
UA 342
STEAMFITTERS
4RunnerChevy
  • Turtle Points: 5
  • Male Posts: 1,426
  • Member since Sep '08
  • Santa Cruz Mountains
    • Santa Cruz Wheelers
« Reply #10 on: Sep 02, 2009, 04:42:28 AM »
Definitly, pretty cool.  The wheels are turning, time to fire up the lathe and mill.
Steve_925 [OP]
  • Male Posts: 1,876
« Reply #11 on: Sep 02, 2009, 09:52:51 PM »
a lathe definatly woulda made it a whole lot easyer
UA 342
STEAMFITTERS
Last post May 14, 2007, 08:47:01 PM
by norcalyoter
Last post Feb 18, 2009, 07:15:45 PM
by STTRUE16
Last post Mar 07, 2009, 12:26:39 PM
by RABIDYOTA
Last post Mar 26, 2011, 12:09:12 PM
by 82rustbeast
Last post Oct 08, 2021, 10:56:08 AM
by Neudaddy
