Formula Toy #31/Re-building my '83
Started by freds40, October 30, 2004, 05:59:26 PM
moutaintoys
 :bowdown: hay bro whats the wheel base looking like?
Lets go break somethin "GO NAVY"
freds40
Well if I just go with stretching the front, it will put me @ 110" I haven't decided if I want to bring the rear forward to keep 107" or not. Finally got the inner shackles made and on so the springs are permanantly mounted. I'll probably remove a leaf since it's looking a little tall right now. We'll see.
"between projects"
UNBREAKABLE
I'm gonna use the same steering arms that you are for my 60.
That's how I roll
freds40
They are pretty sweet. They are flat but clear the springs no problem even without rotating the pinion up just yet.
"between projects"
LCOwner
That thing is a POS you'll never get it done.
Just kidding.  Looks good Brenden.  :biggthumpup:
'71 FJ40, 350 TPI/420, 4.70/mini, 60's/5.38/42's, under construction.
'83 FJ60, SOA underway.  Soon to have a Police 350TBI/700R4/.....
Hill Hoppers Central Valley 4 Wheelers - Founding Member
Four Wheel Drive Club of Fresno - #1127
freds40
Quote from: LCOwner on December 05, 2004, 12:14:51 AM
Shoot, @ the rate I'm going, never is looking pretty good.
I did however get a 4.7 case built (about time) and finally got the inner shackles made. Maybe someday soon the temps will rise and I can get a bit o work done after work. Oh, BTW, this is what my weekend was all about, picked it up in Vegas on Saturday and tried to outrun the black cloud the whole way home!  :bud:
"between projects"
LCOwner
A Dodge huh...  I can here that tractor motor from here.  On a more serious note,  check here and make sure you don't have bad seat belts that Chrysler used.  We believe my nephew died because of them.  www.unsafeseatbelts.com
freds40
Oh this one you'll hear coming more so than other Dodges what with the 5" turbo back exhaust and the custom HX55 turbo spooling up to 50 PSI. Dad was over yesterday and he said he heard me from my house (3 houses from Palm) all the way until I turned off onto Fruit.  :shocking:
Sorry to hear about your nephew, I will definately look into it.
"between projects"
freds40
Quote from: LCOwner on December 05, 2004, 10:27:05 PM
Just checked them and they appear to be the Gen IVs, flat across the top. Thanks for the heads up though Tim, made me nervous thinking of Hazel's seat being strapped in with a faulty belt.
"between projects"
freds40
Been a while. Nothing monumental but a bunch of little stuff.
"between projects"
freds40
Decidedc to lower the front a bit so I basically voided the 2" drop hanger. I'll have to rotate the axle a couple more degrees than already planned but I'm already doing some so a little more is no problem. (never mind the slag, had a bit more cutting to do)
"between projects"
freds40
Cleaning out the cab of everything that I'll be using.
"between projects"
freds40
Gutting the engine bay. Next Saturday I should have the drivetrain pulled. Have to go relax on the beach in Bodega Bay this weekend for my b-day.  :sleepy:
"between projects"
freds40
My diff kit I got from Blue Torch Fab. Little more grinding and it'll be set to go.  :thumbs:
"between projects"
freds40
Finally built myself a 4.7 23 spline case. It's been sitting complete on the work bench for awhile. Can't wait to slow down a bit more on the trails because sometimes duals just don't cut it.  :driving:
"between projects"
freds40
That's about it for now. Hopefully in the next few weeks things will pick up a bit. I've been racing home, doing my "chores" then hitting the garage for a couple of hours for the last couple of nights and it feels great!
"between projects"
dirtyskivies
whens our first trip?  i kept the toy stuff and bought FROR housings and the superduper longfields..
2002 trd v6 tacoma
1986 4runner type thing
1998 ktm supermoto
freds40
Well if Vova's going to set up the father son trip again, I hope to make that. I'll cram the old man into FT #31 and we'l see what it can do.  :rockingout:  Hey did you ever get an extra Aisin hub? I think I still have my spare in the garage some where if ya need it.
"between projects"
crwln73
Looks good Brendan.  The fullsize crew is gonna make a run down to the Hammers as soon as I get my new doubler in.  Broke the t-case adapter last time down. Should be sometime in  March when we head back. Wrecking ball is calling your name.  :yesnod:
freds40
Ken, what's up? You getting bored with all that fullsize stuff so you're coming to the minis for some entertainment?  :haha:
If things go well, I should be 2-3 months before it's wheelable. Next Saturday the drivetrain should be in the new frame, then once I get the new chassis, it's on like Donkey Kong! :_order:   :flamer:   :bud:
"between projects"
dirtyskivies
Quote from: freds40 on January 12, 2005, 08:09:09 PM
formula toy 31??????  throw the spare hub in the back of your truck somewhere:D
2002 trd v6 tacoma
1998 ktm supermoto
freds40
Yup. I figured I have a trailer and the few times I make it to the snow I can bundle up. Mike is working on my DOM chassis drilled to hold air. Should be done in a couple of weeks. By my beginning calculations, after the initial cost of the chassis, I might have another $1K into it to have it up and running. I'm going to keep a record because I know most, not all, but most of the other guys are dropping some serious coin on their's but I have a feeling I can build mine pretty solid by reusing most of my truck while still retaining a little eye appeal.  :bling:
"between projects"
freds40
WHAT'S WRONG WITH MY TRUCK????
"between projects"
freds40
Jacking my own thread here.  :haha:
"between projects"
freds40
And the results of all this smoke......594.5 hp @ 2925 and 1086.8 ft/lbs @ 2850.  :moon:  I smoked out the import shop last night. If I can pull a still from my digi cam I'll show ya what it looked like after this, truck was almost completely engulfed.  :muscles:
"between projects"
dirtyskivies
holy hp/tq numbers!!! i bet you smoke me up 50/icehouse even with your rig in tow!  is that a front bumper or did you smash into a big metal gate and it stuck to your truck?? :ladys-man:
2002 trd v6 tacoma
1998 ktm supermoto
freds40
Are you following me?  :idea:  Yeah that pig was on there when I got the truck. I think I've decided I don't much care for it so at some point I'll see if I can find a stock bumper to throw on it. Unfortunately all my cash is wrapped up elsewhere.
"between projects"
freds40
Finally!!!  :circle:
"between projects"
freds40
 :banana:  :afro2:
"between projects"
freds40
And the reasoning behind this much added work.  :hammerhead:
"between projects"
