Changing a pinion seal with a solid spacer
Started by yjay, August 11, 2009, 06:24:05 PM
yjay
My rear pinion seal is leaking. I'm not very stoked about it either as I bought this as a built unit. Anyway, it has a solid pinion spacer, so I believe all I need to do to replace the seal is remove the nut and yoke, then the seal and install the new one(with some lube)and put the yoke back on right? Should I just re-use the old stake nut and turn it back to the same location or buy a new nut and torque it ? This is the rear of my dd with a detroit .
22re Daily Driver
http://board.marlincrawler.com/index.php?topic=56568.0
91 4Runner-R151f, MC07,23 spline duals, Marlin 1200lb clutch, 85 Front axle, Leaf swap rear, Yukon 5.29's, BFG KM2 35's, Detroit, OBA, 280k
junya92toy
new nut torque it and re stake it. Now others might say use the old nut and tighten itback to the old spot.
4RunnerChevy
Do not return it to its original stake, torque it.
yjay
What is the proper torque for this setup? No measurement of the rotational resistance of the pinion gear is necessary since there is no crush sleeve right?
22re Daily Driver
