60" Hi lift Mount Ideas
Started by Huhwhye, October 28, 2004, 12:02:34 AM
Huhwhye
I decided today that I need to mount my hi-lift somewhere.  I'm tired of it banging around.  I have the big 60" model and its kinda cumbersome.  I also have an over the rail tool box in the bed so mounting it on the bed side would take some creativity.  I thought about mounting it the the floor of the bed but I don't know if thats such a good idea. :dunno:
Any suggestions?
'04 Taco DC 4x4
Mount it below the bed just behind the rear bumper (or in front of I guess) or somewhere down low.
Keep the weight down low
BLUCRUZ
Why not mount it to the rear facing side of the toolbox?
72 FJ40. 350 Multiport EFI, turbo 400, ORION T-case, 35 Procomp's  disk brakes front & rear, ARB's F&R and an onboard shower for the ladies!
86 sr-5 4runner SAS conversion. E-lockers F&R, 5.29's 4.7 Marlin case.
Fireimp141
Mount it behind the box and in between the cab, on the rail between the metal and the glass. Should be easy there :thumbs:
Why not mount it to hte tool box crossways?  I have mounted mine by drilling a couple holes in the top of the fenderwells and bolting it down and Ive also welded a couple 1/2x2" bolts to the front bumper and mounted it there.
You could always mount it to the top of the cab and put some hella bright lights on it :gap:
No no no, ya gotta do like some of the heepers and mount it to the hood next to your freshly waxed shovel. :gap:
Huhwhye
Its too big to fit sideways in front of the box.  And if I put it behind the box, the box can't open all the way.  The jack measures 62" top to bottom.
'04 Taco DC 4x4
Shamb
i thought about mounting mine to the inside of the bed resting on the fender well but bolted to the side. That or just connect it to the back like most do.
UNBREAKABLE
Don't use it for a jack. I think that a high-lift is freakin' dangerous. I've seen them bend!
That's how I roll
Huhwhye
Yeah we used my friends high-lift as a big lever to fix some bend steering parts.  The jack bends pretty good.
'04 Taco DC 4x4
Jared
i use them on the ranch i work at and i bent one so bad you could catch a shark with it... The good thing about them is you put a tractor bucket over them and they are good as new after wards...
Huhwhye
Well I didn't get it mounted in time.  That's ok, I'll work on it next time.  I think I want to shorten it a little bit so it fits sideways between the bed rails, only need to cut off 4 inches.  Then I think it will be easier to mount.  Thanks for the ideas.
'04 Taco DC 4x4
nowhitefenders
 :D  I have mine mounted to the front bumper, using the stock mounts.  Seems to work alright for me.
Robert
www.nowhitefenders.com
www.my4x4tv.com
Shamb
looks like the base over hangs on the end, ever get it caught on something?
Mike D
just stick it on you roof..... super glue or a hot glue gun will do the job  :yupyup:
nowhitefenders
 :usa: Oh, yeah I see from that angle looks like a rock grabber.  But I haven't hit it on much more than tree branches on super narrow trails...  The jack is no wider than my fenders so no problems.
Robert
www.my4x4tv.com
toyman2
i mounted mine resting on the pass. fender in the bed  with a  1/2in bolt and a nut  to keep the
bolt on the fender with a nut and washer for the jack and for one that long you might want to but a bolt behind the tail light so the base has somthing to rest on and i have no rattels
el gato
I welded two bolts to my bumper and wraped my winch cable around it.  It works just fine.   :beerchug:
