Broken 4 wheel drive.
Started by BLACKDOG, October 27, 2004, 07:54:31 PM
BLACKDOG
Ok, I finally got around to pulling the cover off my front differential.  What came out was a shaft that was broken in half, and two gears, or chunks of gears i should say, that were about the diameter of a tennis ball.  I will post pics when I get home, but I was wondering what exactly that means to me, what I need to replace, and how much should it cost??
Also, any background on the front diff would be helpful because everything I know I learned today taking it apart.
Oh yeah,
1991 V6 5speed IFS
              -Ronald Reagan
KYOTA
sounds like the cross shaft and spider gears, dont waste your time and money fixing it, this is the perfect excuse for SAS !!
Yes, ditch the ifs, it will be the gest decision you can make.  spider gears are crap anyway, lockers are better.   :biggthumpup:
BLACKDOG
how much do spiders cost to fix?? :dunno:
I dont have a choice on the IFS right now If I had money, I would swap it out
              -Ronald Reagan
BLACKDOG
pic
              -Ronald Reagan
BLACKDOG
are those the spider gears??
I dont know anything about gears, so please, help me out
              -Ronald Reagan
Skinny_Pedal
i know a guy that is selling a front diff w/ 4.10's for $10
Im an OG
BLACKDOG
Really?  mine were 5.29s, but obviously not anymore
              -Ronald Reagan
brainlessfool
them's the spider gears all right. if you don't have the $$ for a SAS just stay on the street untill ya do. or you cloud blow some $$ and put in a locker in the front for now.
BLACKDOG
86runner, what shape is that diff in?? is it for IFS??  If so, I am interested.  How much do you think it would cost to ship to CA??
              -Ronald Reagan
KYOTA
Saw this on Webilts forum  http://webilt.com/forum/viewtopic.php?t=97  no contact # so you'd have to register and PM him. These guys are N. Cal so good for you
SWAMPER
Man those are some good buy's If you dont want that third blackdog let me know so I can get it...it has the same gearing i do
Are spider gears the same for the 8 inch and 7.5 inch?  Or are they different sizes?
SWAMPER
I think their different but I also have a 7.5 so I woulnt mind that diff there :drool:
Mike D
BLACKDOG
              -Ronald Reagan
Skinny_Pedal
dunno. not to much. i can get the link again if u need it
Im an OG
BLACKDOG
Ok got some stupid questions
When I have a locker in the rear, that pretty mich replaces the rear gears correct??
Also, I am looking at getting the IFS third off the link Kyota posted up.  I had 5.29s and it has 4.56s  Will that matter at all?? I know it isnt ideal for bigger tires, but I need my 4 wheel drive back.  It is off a 94 v6 pickup.
Will that fit onto a 91 v6 pickup??
              -Ronald Reagan
KYOTA
A locker like a Detroit or ARB replaces the entire carrier and the ring gear is bolted to it, a locker like a Trac-lock replaces the spider gears in your existing carrier. And yes the gear ratio's must be the same front and rear so if you get the one I linked to you'll have to have it re-geared.
BLACKDOG
would it be better to get that one regeared? or have mine regeared??  Since the spider gears and stuff basically shattered, would it be better to use a diff housing that hadnt had that happen?? or does it matter?
              -Ronald Reagan
SWAMPER
Yes because then it will feel like your axle want to swap places :ack:
I dont think it matters if  u use the same one or not
KYOTA
Inspect the carrier you have, but I'd guess that since that cross shaft broke, the holes in the housing where the shaft goes is probably wallered out a little. You may be better off replacing the whole carrier
BLACKDOG
Thats kinda what I was thinking.  Flying metal in small spaces doesnt do well.  Thanks for the input.  How much m i looking at to get it regreared??  About?  I've heard $100-$800 and anywhere in between.
              -Ronald Reagan
SWAMPER
The gears would be like 100 bucks plus the master gearing kit onother 100 bucks plus add 150 bucks or so if your getting them installed by a shop
BLACKDOG
ok so 350 or so.  Thanks lil swamper. 'preciate it
              -Ronald Reagan
SWAMPER
Im giving you a "cheap" price but its around that ball park also shop around for the install some ppl will jack up the instal price big time man :snare:
Mike D
you may also have killed some of your bearings
reklund5
I have an IFS Front diff assembly laying outside as well if it will help you out.  Its got factory 4.10's in it, but I'll install whatever gears you want if you send me the gears and a few bucks for labor, then send the entire thing out to you so you can just swap it in.
BLACKDOG
thanks to all.  Lilswamper, if you wanna try to get that 4.56 gear set go ahead.  I think  I'll have reklund do the gears once i get the money.
Also, what exactly do i need to buy in order to fix this problem?? I have never doen this so i am not sure
              -Ronald Reagan
SWAMPER
