Quick help, Welding
Started by jrock, August 06, 2009, 08:51:58 PM
jrock
So I rented a Lincoln 125 from Homedepot and I'm having some issues. First, I have done VERY little welding. Okay, the issue is the welder doesn't seem to be putting out any juice. I have it on High AMPs and a moderately slow feed and the damn thing spits and splatters a ton. Then I can't get a decent bead to save my life.  :help:
The beads look like this. HELP because... HOLLY S@#T BATMAN!  :willynilly:
jrock
I should also add it's running off of a 50ft extension cord. 14gauge.
junya92toy
first off, its volts and wire speed. wire feed and amps are the same on that welder. what size wire are you running and what type what polarity are you using, gas? The volts dig the hole. Plus more volts the flatter the weld will be, to point, if the bead is humped, turn the volts up maybe or try turning down the wire feed speed.
snowshoebrue
is it a mig/flux welder?  you might have the polarity reversed if it is
junya92toy
and for the sake of safety practice on scrap first
jrock
.035'', no gas. Flux core. As far as I can tell I can't change the polarity.
Yeah, I checked for scrap and had none.  :shhh:
DeadlyPeace
If you open the side door there should be two thick cables with wing nuts. Usually have a + and - cut into the panel next to them. Swap them around. Should show on the inside of the door where they should be.
I REJECT YOUR REALITY AND SUBSTITUTE MY OWN
Never let people think you're a horrible person and always keep the heart of a young child...
       ...I prefer mine in a jar on my desk.
3 CAT scans a MRI and some time with the shrink and it's comfirmed. I'm just not right in the head.
Global Moderator for www.ToyotaOffRoad.com
jrock
Quote from: DeadlyPeace on August 06, 2009, 10:07:36 PM
The + is on the ground and - is on the gun. Should I change that?
DeadlyPeace
That should be correct.
Also from the looks of the thickness of the metal I'd said set it on C (heat range) and about 3.5 (wire speed).
jrock
So right now I have it at E and 3.5. Any lower ltter and it spats a ton. If I lower the feed it takes real long to pool.
DeadlyPeace
Two more things.
1. Check the drive wheel to make sure that the larger of the two groves in under the wire and lined up right.
2. Remove the wing nut on the spring load pressure arm and thighten down about eight full turns.
zippo
Before i do anything i would grind that crap out. In looks like it is cracked and has zero penetration. Welding over that it will never be right.
Why the hell are you running over a 50' 14G cord. I wouldn't run a drill off that. Get a new cord!
As far as spitting and such, Flux Core does that. Get better wire and it will help, but it will still spit alot.
Good Luck, take your time. With mig welders its all about the settings. You might also try renting a better welder from a different rental store.
If you see it, its for sale.
junya92toy
jrock
I'll pick this up in the morning and I will check all of the hints. Thanks for the input. :)
DeadlyPeace
#14
Deffently don't be welding over will not help. You will want to grind that completely off first.
The cord should be ok, but a heavier one would help.
Another thing to check is the wing nut for the wire wheel. Make should it's just lightly tight. Just enough to keep the wire from unwinding.
Jud
Rent a wire welder with gas if you can. Flux core sucks especially if you aren't very good at welding. The only time I use Flux core is for stuff like cast or welding spider gears because If you know how to weld with it and you have a small machine (like my Hobart Handler 140) you can get more penetration. It does take longer to pool than with gas and doesn't look very good until you chip the slag off.
"bout tree fiddy"
crazykooter
I weld with a HF special which is not nearly as good as Lincoln but its more about tip angle, how close you are and the speed of which you move.  I am not a good welder but I am learning little by little.  Not that it compares but I run a wire speed of 7 on high.  Here is a pic of the last weld I did.   I was having same sort of welds when I 1st started too.  I can say .o35 wire is too heavy for that machine.  I run .030 flux core from a welding shop near me and it lays down much better.  Some times too slow of a wire speed will cause the arc to become erratic since your gonna burn the wire so fast that you wont be able to keep the 1/4" distance u want.  Tilt the tip at an angle so you can see your weld being laid down. If you start to see that your out running your puddle then dont stop just move your weld back to it and cont.  Hope this makes sense as its 2 am and just woke up.
zippo
Just for reference. Some GOOD welds. The weld lays in, and needs no grinding "or paint" to look nice. At the edge of the weld you have the slighest lip just enough to catch for finger nail in. Shows good penetration. You can also see where the puddle was and how the weld was pulled, as well as the heat as it entered the metal. I cant stand a bad looking weld, and will cut it out and redo it. I wouldn't trust my life to the top weld pic.
<img src=http://oppiz.net/pics/yota/05152009/DSCN2678.JPG >
<img src=http://oppiz.net/pics/yota/Front%20Axle/DSCN2527.JPG >
<img src=http://oppiz.net/pics/yota/05062009/DSCN2632.JPG >
jrock
Shoot, Zippo, those are nice! So I turned the feed down and the letters up and it did the trick. Not nearly as nice as Zippo but 200% better than before.
MiniSimp
Just make your welds look like this:
I have no idea how though :gap:
jrock
HAHA! Riiiiiight. Maybe next century.  :willynilly:
junya92toy
those beads are too far apart
Crawler677
Quote from: jerry92toy on August 07, 2009, 08:51:15 AM
hahaha, yerp.
From that first pic. i feel like your wire speed is too high. Also it looks like your all over the place (this happens when wire speed is too high because its always trying to push you away. go buy some metal at home depot or something and fiddle with your wirespeed and voltage. youll get it.
another thing to check is your line voltage. but this is rare.
jrock
Yeah, right on. The wire was trying to push away from the metal. Thanks.
zippo
look inside the case, and it should have a chart that will give you ballpark seetings. Might help
potter85
remove the extension cord, go to a smaller wire turn the heat all the way up and adjust the wire speed accordingly run it uphill and if the metal is just too thick for the welder give it some pre heat
3rz in the making
looking for 38s
2 tundra 4.7l v8 soon to be sas'ed
crwlntoy
Quote from: potter85 on August 07, 2009, 03:09:21 PM
[/quBINGOote]
If God didnt want me to eat animals,then why are they made out of meat?Wackum & stackum
junya92toy
So hows it coming along?  Got any new pics?
jrock
Nah, I returned the welder this morning. I was getting much better welds after the adjustments thanks to you guys. I really need to buy a welder so I can practice all these different things. When you rent you just don't have enough time. I'll snap a pic of what I finish with.
